Online: Merv
M8 Oil pumps Upgrade
  • Deputy Dog
    Deputy Dog
    6 years ago
    New HD upgrade oil pump to suit M8 HD PtNo 62400247. Have checked and not available in Australia yet.
  • DocGreen
    DocGreen
    6 years ago
    Deputy Dog, not sure where you got that info mate, a few guys on here have already had the new pump installed. I ordered mine late December and should have it end of February.
    I believe HD are having supply issues with quite a bit of gear,  so don't be in a rush mate.
    DocGreen.
  • Deputy Dog
    Deputy Dog
    6 years ago
    Sorry Doc, I should have said nil stock in Aust. I tried to get get one through Perth Harley. S&S might have to do. Cheers
  • DocGreen
    DocGreen
    6 years ago
    Quoting Deputy Dog on 03 Feb 2020 09:55 AM
    All good mate, the HD pump isn't too pricey, I can check but think its just over $260 for new pump and cam plate, but you'll probably have to wait.
    DocGreen
  • Birtyyy
    Birtyyy
    6 years ago
    Any more info on this update? What's the benefit of the new pump over the old one? Is is just for Touring or Softail as well?
  • DocGreen
    DocGreen
    6 years ago
    Quoting Birtyyy on 03 Feb 2020 08:11 PM
    Hey mate, pump fits both softies and tourers, new design with improved scavenging meant to reduce likelihood of sumping (hopefully) also has a seal on the back of the pump which I believe acts like a one way valve. Haven't heard any negative reports yet, as opposed to all the other pump revisions on the m8 engine. Figured I'd upgrade while in there doing my cam as fairly economical.
    DocGreen
  • STEAMER
    STEAMER
    6 years ago
    I believe they were up to vetsion 5,  late last year. And were available then. So if they now saying not available YET in Australia. I reckon they have another newer version.
    Just my opinion
  • DocGreen
    DocGreen
    6 years ago
    Quoting STEAMER on 04 Feb 2020 06:58 AM
    Just my opinion
    Steamer, you can get the latest 8 lobe version, it'll just be slow turning up. Ordered mine end of December,  due end of February.
    DocGreen
