Online: B0nes, Stuart
Revs... no tacho
  • coyoty
    coyoty
    6 years ago
    My 2000 Softail doesnt have a tacho,  5 speed, std tyre dia,   100ks / hr in 4th =   ?    rpm              Thanks in advance,
    6 years ago
    Try this site... I use it all the time when messing with sprocket ratios.
    https://www.gearingcommander.com/
  • coyoty
    coyoty
    6 years ago
    thanks, will get onto it
  • imoo6170
    imoo6170
    6 years ago
    Quoting tussuck on 01 Feb 2020 02:36 AM
    Brilliant site - thanks for the tip
    6 years ago
    Yep....In theory the FXR should do 150mph with her current gearing.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Thanks for the link.
    6 years ago
    You might find an iPhone app that can do it.  In the end I went with a Zetronix unit to tune and setup the carbby system.
