Online: B0nes, Stuart
FXDXT Wheels
  • Train
    Train
    6 years ago
    Anyone got  a pair for sale. Looking to put on my 2011 street bob. Cheers
  • John.R
    John.R
    6 years ago
    Aren't FXDXT wheels just 13 spoke Sporty/Dyna wheels?
    Or is there something specific with T Sport wheels.
    6 years ago
    Twin disc front hub is the only difference.
    Also,  Rear is only 3.5" wide, a bit small for a street bob.
  • Train
    Train
    6 years ago
    Quoting speedzter on 27 Jan 2020 09:16 PM
    Yep. After the front in particular
  • John.R
    John.R
    6 years ago
    Isn't every 13 spoke rim out there twin disc though?
    Also an FXDXT should only have a 3in rear from memory, that's rim width.
  • John.R
    John.R
    6 years ago
    My only point being, your far more likely to have someone hit you up with a 13 spoke Sporty wheel in their garage then an FXDXT of which there are stuff all out there, even though theyre the same wheel.
    I sold mine a little while ago, have seen a fair few pop up but not at prices im keen to pay.
  • Train
    Train
    6 years ago
    Quoting John.R on 28 Jan 2020 12:03 PMedited: 28 Jan 2020 12:04 PM
    Are the sporty and dyna wheels exact same as this? I'm after this wheel
  • John.R
    John.R
    6 years ago
    Exact same, including colour? It depends on the model, sone are raw.
    Look up 883R wheels, they're the same as  your pic. I would say compare part numbers but the bearing size might throw it off if its different.
    Like I said, I'm about 99% sure that there was only 1 cast of that kind of 13 spoke wheel. I've literally never come across a single disk only 13 spoke wheel. The hub has always been for dual discs and a block off plate used if not running duals.
    6 years ago
    Yep, have those on my 883L except single disk on the other side, BUT there is a screwed on blanking plate on the other side so you can run twin disks.
  • Train
    Train
    6 years ago
    Quoting John.R on 28 Jan 2020 08:19 PM
    Sweet thanks mate
  • Train
    Train
    6 years ago
    Quoting tussuck on 28 Jan 2020 08:52 PM
    Perfect, Cheers
    6 years ago
    Quoting John.R on 28 Jan 2020 12:00 PM
    To be honest, I was thinking of wire spoke, as it didn't say cast in the OP.
    My FXDX had a 3.5" wire spoke rear.
