Online: B0nes, Stuart
Workshop Lighting...What do you run?
    6 years ago
    Hey, new shed is built and I was wondering what sort of lighting folks use?  I have some old Floros but is there anything else like LED?  What colour lights as well... as even white varies nowadays.
  • Wideglider
    Wideglider
    6 years ago
    Can't beat flouros, 4 foot doubles, lowered to right height with jack-chain. Use colour 865 (cool daylight) for work areas or moving machinery.
  • steelo
    steelo
    6 years ago
    Got some weather sealed led flouro bars which have off on timer and proximity detection and about a 5 m extension cord from Aldi.
    Put 2 in my 6 x 9 m garage with an in-line switch to power board. At about 80 bucks each and no electrician.  Turns night into day. Cool white light.
    Edit. Mrs tells me they were a special buy. But it’s an option.
  • brucefxdl
    brucefxdl
    6 years ago
    where i work have led lights,they're about 30 cm square with multible leds and give off a reasonable light and are probably 9-10 metres from the floor [ large workshop].
  • brucefxdl
    brucefxdl
    6 years ago
    looks nice and clear in your shed steelo,nothing like having good lights.
    6 years ago
    You can now get quality (Phillips, etc) 4 foot LED battens from electrical trade outlets ( Auslec, middy's ...) for around $50 ea.
    When I did my last shed about 2 years ago, they were harder to get, so I used twin 28w Fluro's with electronic ballast's - no flickering or starters, $40ea.
    Aim for around 4000k to 5000k colour temperature, or cool white.
    6 years ago
    I have LED fluro's they are bright & come on quick.
    6 years ago
    Cheers guys.  I have two 8' long banks of 4 x flouros installed today.  I'll swap out the Flouro for LED though as they are cheaper to run (damn the power companies and their smart meters!)
    About 4000 to 5000 looks good!  I'll populate one of the banks and see how it looks.  Plus I'll still need some down lighting over the workbenches etc.
    Next stop is the Airconditioner....lol
  • steelo
    steelo
    6 years ago
    Second hand swampys are cheap. Do the whole shed and you can leave the doors open.
    6 years ago
    As in a swamp boat?  I'm a Kiwi, you will need to simplify the answer
  • steelo
    steelo
    6 years ago
    Sorry t. It’s an evaporative cooler. Prob more popular in sa due to it being dryer. People get second hand / or new ones and put them on the shed with a four way diffuser. They work a treat.
    6 years ago
    Ahhhh.  I'm thinking reverse cycle unit for summer / winter - lucky the son is a commercial aircon plumber
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Use cool daylight tubes or LEDs the yellow soft light of warm white is shit when working on stuff.
    The new LED type of lighting are now about the same cost as a traditional fluro twin tube unit, better light and you never have to get up to them again to change out a bloody tube.
    O and never use a fluro over a rotating shaft or lathe, due to its ability to make the spinning shaft look still at the right time due to the 50 hz cycle of the tube.
  • RossW
    RossW
    6 years ago
    Quoting steelo on 27 Jan 2020 06:25 AM
    Not likely to work very well in Melbourne. They rely on low humidity to work efficiently.
  • Baloffski
    Baloffski
    6 years ago
    Quoting RossW on 28 Jan 2020 02:21 AM
    ok I'm with you Ross, lights and coolers, both go together.
    Evaporative coolers seen working well in the Nor West, Perth,  in Sth Aust. Desert Aus. as dry.
    My pissant little shed has LED fluros, so easy these days to just plug and play, so old cunts can see what the fuck their doing.
    When working a real job, Comms rigger, saw under Broadcast mast, can kick start a fluro in ya hand, no power hooked in, radiation, is no wonder the old rigging crew have been dropping off like flys.
    Wonder if that would work with LED tubes?
    6 years ago
    Quoting Baloffski on 28 Jan 2020 03:14 AM
    Nope.... It is the RF waves ionise the gas in the tube.  We did this at TAF to validate wavelength theory, awesome stuff.
  • Big Steve
    Big Steve
    6 years ago
    I'm slowly replacing my fluros with these:
    https://www.ebay.com.au/itm/263682494593?ul_noapp=true
    Bought one to test and its plenty bright so I will order a few more.
