Online: B0nes
Supercharged Night train build.
  • Ricca
    Ricca
    6 years ago
    Thought i would give you all an update on my Pro charged Night train build!
    After blowing my stock crank i decided to build a tough engine and slap a supercharger on it!
    - Bike 2007 Night train.
    Bottom end:
    Darkhorse Man o war crank / timken bearing conversion
    All new strengthen balances
    Feuling Race serice Oil pump
    Feuling Race serice Cam plate
    Feuling Hydraulic Tensioner Kit
    SE - 211 CAMS
    - Few other bits
    - Top end:
    S&S 107 KIT with Carrillo pistons ( Thicker walls = less heat build up )
    96 Heads sent to Rams over east to be CNC , Ported , works all done <--- Def recommend them , Greats service and turn around time.
    HPI throttle body
    Blue band injectors
    Clutch Basket / Hub all replaced with billet.
    Pro charger B-1 - 12 PSI
    Few other bits and bobs, but these are the main Items
    Currently running her in still, currently tuned at 170 ish hoping for 190 +
    www.instagram.com/westcoast.garage
  • Far Canal
    Far Canal
    6 years ago
    Looks awesome Ricca, no excuses for being late to church now.
  • Ricca
    Ricca
    6 years ago
    Quoting Far Canal on 16 Jan 2020 09:47 AM
    haha cheers mate
  • Chaser
    Chaser
    6 years ago
    Very nice indeed. The Nightrain has always lended iteslf to be modified in so many ways....similar to the breakout.  One question - is the front guard for that sized wheel? - it looks a tad small with the curve not quite following the diameter of the wheel.
  • Ricca
    Ricca
    6 years ago
    Quoting Chaser on 16 Jan 2020 09:56 PM
    23 inch Front wheel / 23 inch front RWD fendor, just a different style didnt want a long style. Could be the photo angle aswell i guess.
    Your are correct. Breakouts / softys are perfect to customize to suit you needs
  • Birtyyy
    Birtyyy
    6 years ago
    That must be a lot of fun to ride...
