Online: obisteve
Detachable Sissy
  • markmckenz
    markmckenz
    6 years ago
    I'm looking to get a detachable sissy for the missus when she gets on the bike. I have a 2-up seat so I just want to be able to attach and detach the bar quickly enough.
    I'm thinking along the lines of these, can anyone recommend a full set up?
    https://www.harley-davidson.com/store/1-piece-detach-upright#tabs
    https://www.jpcycles.com/product/166-7343/cobra-black-quick-detachable-11-square-bar-sissy-bar-with-backrest
  • brucefxdl
    brucefxdl
    6 years ago
     i have a qd bar/rack combo from HD that works well,style is similar to the cobra one you linked,medium height with a pad,wife reckons its good and holds a roll bag well.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I have the HD unit with the gear rack, pretty good. Is quick release.
  • markmckenz
    markmckenz
    6 years ago
    Any links gents?
    6 years ago
    In all honesty the Harley one is pretty good.  I had one on my Sporty and with the quick release tabs you could remove it in 5 seconds and put it back on in about the same time.  They are never cheap (and do not forget the back rest pad as well) but for a pillion they are the bees knees.
  • RossW
    RossW
    6 years ago
    Quoting tussuck on 15 Jan 2020 11:06 PM
    I have one of these as well. I swap it for a top box bolted to a HD bracket when I need one. It's very easy to remove and replace and is very secure when fitted.
    Not cheap though.
  • potluk
    potluk
    6 years ago
    gidday mate you didnt say what model dyna you had but the cobra product looks like it is for a sportster.maybe check this one out https://www.jpcycles.com/product/903-657/cobra-black-quick-detachable-14-round-bar-sissy-bar-with-backrest it is the same price. i have a 2014 street bob and getting a sissy bar hooked up to it with docking hardware was a fucking nightmare. you cannot get 4 wires through the docking hardware so you have to run wires under the guard and that looks like shit. anyway i have had my say on this site before about that so enough said. having said that if only this product was around at the time i bought my bike the docking hardware looks like it bolts on above the indicator therefore you dont have to put wires through docking hardware leaving you a nice clean look when the bar is off. you should grab the luggage rack while your there they come in handy. if i can offload mine i will look at one myself. hope this helps. cheers
  • markmckenz
    markmckenz
    6 years ago
    Cheers boys.
    I’ve just purchased my third street bob, this ones a 2014 so it would need to fit that.
    What is the HD sissy? I had the luggage rack/passenger pillion on my first one but I have a 2up seat with this one so keen for a detachable sissy instead.
  • St33tbob16
    St33tbob16
    5 years ago
    I prefer to run my Streetbob as a solo seat so I purchased the Genuine Harley Detachable Sissy bar.
    Itl gives the bike an old school look and allows me to still run just my solo seat.
    The other bonus is when I go away for weekends etc the Momentum Deadbeat duffle bag straps to the sissy bar perfectly.
    https://rolliesspeedshop.com/shop/windshields-luggage/luggage/travel-bags-associated-parts/kuryakyn-momentum-deadbeat-duffle/
  • micathia
    micathia
    5 years ago
    Quoting St33tbob16 on 23 Mar 2020 03:16 AM
    Where are your turn signals? front/rear?
