Online:
B0nes, Stuart
Sporty 2-1 or 2-2 exhaust options
HOG63
6 years ago
Hey guys. Seeking opinions on the best sound on an 883 Sporty (carby), idling and riding.
Who prefers the 2 into 1, or the 2 into 2 sound (and appearance)?
HOG63
6 years ago
Anyone?
6 years ago
2-1 for performance with good sound
2-2 for better sound but at the expense of a 'very little' bit of performance
The decision is TOTALLY subjective and varies from rider to rider. Me; I'm a 2-2 guy on all my bikes except for rice burner racers.
HOG63
6 years ago
Thanks Tussuk.
Some say the bigger engines sound better as 2-1.
6 years ago
Well I used to run 2 into 1 , then went 2-2, at the time I was also drag racing my Harley & riding it to the track's I raced at. I thought the 2into 1 gave more HP but after changing from 2 into 1 to 2-2 I went 5 tenth's of a second quicker and 12mph faster in trap speed. I have never gone back to 2 into 1. also at the time I was using a Dynojet 250i for tuning , & on the dyne the 2into 1 made more Torque at lower rev's , but at 3,500 rev + the 2-2 went away and made more TQ above 3,500 and carried TQ to higher rev. well for the street if your mostly at lower rev's plus being an 883 could make it feel stronger using 2 into 1 with a bit more TQ down low. I like the look of 2-2 I like the sound of 2-2 so I'll stick with 2-2 myself. depends on what you like. also I thought I'd note if you take the silencing out the muffler on 2 into 1 you can make good HP just too loud for the street. supertrap you can tune them & keep them quite, but personally I had no luck with them making good power quietly . they made less HP quite but when louder made more HP.
it's your bike so go with what you like personally!!If you reed between the lines, you get the idea, I'm not worried about sound, I get more excitement getting thrust forward when I twist the throttle open. I also like the truth.
HOG63
6 years ago
OK that’s interesting re the speed/power.
Being a small engine capacity I guess the lower end power is more desirable.
HOG63
6 years ago
Anyone have experience with 3” Cobra slip-ons?
HOG63
6 years ago
Thanks Postie. I looked for Grenades but none fit this 05 bike. Might get the Cobras.
And with stock pipes the loudest thing is your engine.
6 years ago
I'm glad you took the grenades off...they are one fugly looking pipe imo.
HOG63
6 years ago
Thanks Postie.
I found some Rush ones on eBay that aren’t too expensive either.
micathia
6 years ago
Melbourne's Harley Heaven is doing a promotion on VH's 2-1 blackout sporty pipe, $250 cheaper than listed price. In case anyone is interested.
