Online: Merv
Starter motor
  • graeme
    graeme
    6 years ago
    Went for a ride today on my lowrider started up 1st go went 2 kms went to mates place shut it down tried to start after 5 minutes starter just making a grinding noise not cranking motor battery ok any help would be good
  • Far Canal
    Far Canal
    6 years ago
    You are not getting an avalanche of help here Graeme which is a pity.
    Harley starter motors are in a really awkward place to easily get to which is why I suppose most folk go straight to the nearest shop for help when there is an issue.
    Thankfully never had an issue with mine.
    Let us know how you go.
  • graeme
    graeme
    6 years ago
    Thanks mate will have to go to a dealer I think I replaced stator and regulator last year I tore the teeth of starter clutch when it backfired the year before wish I had kept it standard now instead of hicomp
  • Far Canal
    Far Canal
    6 years ago
    Have you souped your motor up a bit Graeme?
  • graeme
    graeme
    6 years ago
    Yes mate se heads 1550 kit 211 cams mikuni tuned by lushy 100hp
  • markwoumla
    markwoumla
    6 years ago
    Quoting graeme on 14 Jan 2020 10:27 AM
    If all cables and voltages are ok ,all evidence points to the starter clutch, (seems like you have history there).. Hope you have not done any damage to the flywheel !!
    A weak compensator can have a negative effect on the starter motor, (starter clutch)....  This together with a high comp engine will see the weakest link start failing , ie starter clutch....
    Depending what model/year bike,,you could drain primary oil,, remove primary cover,, and have a look... You could also hit the start button and have a dry run , (wont hurt anything for 5 or 10 seconds... Just make sure its outside, as residue oil will spray all over the place....  Good luck ...
  • graeme
    graeme
    6 years ago
    Bike fixed new 1.7 kw starter motor
