Online: Merv
FLSTF Fatboy 2014 Exhaust Advice needed
  • FATTY1
    FATTY1
    6 years ago
    Hi All,
    Does anyone know what the round fitting does on the original exhaust. Its a cable fitting with a wire that runs to the engine, it seems to spin at some point. How does it come off? and why doesnt my replacement have this fitting to re attach?
    thankyou
    alex
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Is it an O2 sensor ?
    6 years ago
    About 8" from the exhaust port at the heads?  O2 Sensor.
    6 years ago
    Quoting FATTY1 on 09 Jan 2020 09:17 AMedited: 09 Jan 2020 09:42 AM
    Hi All,
    thankyou
    alex
    Maybe a pic......
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Come on Paul what is the fun on that ;)
  • FATTY1
    FATTY1
    6 years ago
    hi all,
    thanks for the replies, pics uploaded...
    anyone?
    alex
  • joey
    joey
    6 years ago
    It’s ya flapper valve
  • FATTY1
    FATTY1
    6 years ago
    ok, so what does it do? can i remove it safely and how?
    thankyou all.
    alex
  • Grease Monkey
    Grease Monkey
    6 years ago
    If you have a flash tuner turn it off in the cal and unplug it, you can then take all the actuator stuff off, if you can't turn it off get a dealer to do it for you. It's just a valve to limit gas flow.
    6 years ago
    Grease Monkey is on the money. It acts like a butterfly valve and is a twofold purpose. Supposed to increase TQ at lower rpm by remaining closed then opening up for better flow at higher rpm. The second was to limit exhaust noise for epa at lower /idle speeds. As Grease Monkey said you can deactivate it with your tuner
  • Retroman
    6 years ago
    Fugg me this question 13 years on !
    This is the "Active Exhaust" in Harley speak , it is NOT on US "Domestic" bikes only on some market 5HD vin numbers including EUROPE
    We in Australia get the Euro spec bikes 100% ( bar the LHD headlights !). Have done since October 2006
    I said the 'zact same thing to Frasers HD in Perth in October 2006. "What the fuggzthat ?" Re my new 2007 FXSTC just arrived in Oz
    AND THEY DID NOT KNOW I KID YOU NOT !
    So I found out and told 'em you betcha. I Worked out you could "fool" it and not trigger a fault code by just screwing or riveting the flapper in the open position.
    So I tells Frasers and they started doing it at PDI on many bikes. I did many bikes for mates , and 13 years on they are still running allright, flapper screwed open.
    I have now worked on many "Grey imports" both from the USA and Japan and they do not have this "Active exhaust' system. ( we also get "active air" they don't !)
    It is not to increase torque , it is purely for Euro spec "drive-by" noise testing while you are in metro areas like Paris for example.
    They strangle the bikes to buggery and always did.
    If you change out the stock headers , as in fitting a V&H system for example you just unbolt and unplug all that bullshit along with the stock exhaust.
    If you have a "race tuner" for the bike then there are calibrations or "'MAPS" that allow you to switch off or more accurately "disable" active exhaust and air.
    You may then have to over flash the bike again with a calibration for your model/cams etc etc. Not all calibrations allow toggling OFF and ON
