Online: John.R, perthhog
Unknown rattle in/on my 2008 Nightster.
  • night_prowler
    night_prowler
    6 years ago
    Hey folks,
    So I’ve got a bit of a rattle going on on/in my Nightster and I can’t figure out what it is. I think it’s done it since I’ve owned it but once I got my new chain and sprockets fitted I swear it’s way more noticeable. I thought it would have had to have been the kickstand but I’ve zipped tied it to the frame and also tried flicking it down with my boot while travelling along trying to replicate the sound and just cannot get it. The odd thing is it’s only really while the throttle is open and it only occurs when you’re hitting bumps in the road, on a nice smooth bit of black top it won’t do it whatsoever, no matter the RPM’s or gear but hit the right kind of bump in the road and it’ll rattle, sounds like a bit of tin touching the frame but I’ve gone over it time and time again and can’t find shit. I have heard it only for a split second when hitting bumps with the throttle shut but it almost never does it unless it’s open, regardless of the degree to which it’s open.
    I’ve tightened my primary chain, it was a bit loose and I topped the transmission fluid up but it’s still just a touch under where it should be (waiting for the fluid to come in the post, local dealer is shut for the holidays for another week) but it’s still covering the chain. I’ve checked any suspect bolts and have found nothing.
    It runs and rides like hell, it’s super reliable and since I’ve had all the tuning done it’s riding brilliantly but this rattle is driving me up the fucking wall. If anyone has any ideas it’d be much appreciated! Can’t find shit on google.
    And it’s definitely not pinging, been through that shit already!
    Cheers ladies and gents!
    6 years ago
    Check the rear exhaust pipe mounting bracket as they can break but still stay attached and make odd noises.
    Is it a rattle or a thud/thump?
    - check rear swingarm bushes and bolts as they wear
    - steering head bearings can knock when worn (or even a loose steering bolt)
    - Check the front fork oil levels and in fact just replace it anyway - low oil can cause noises there.
  • night_prowler
    night_prowler
    6 years ago
    Sounds like a bit of tiny rattling against something solid if that makes sense, it’s initiated by bumps but at low rpms it can sometimes carry on for a few seconds so it’s almost like the engine vibration keeps it going. It’s really bizarre, definitely not exhaust mounts, I’ve been meaning to drop the forks out and change the oil anyway because it’s likely that it’s never been done... see how that goes. Cheers Tussack!
  • Soapbox2627
    Soapbox2627
    6 years ago
    check your side stand, spring and bracket
    may be that simple
  • night_prowler
    night_prowler
    6 years ago
    Quoting Soapbox2627 on 02 Jan 2020 10:24 AM
    may be that simple
    Cheers Soapy, checked all that but seems to be ok
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Also check your heatshields.
  • night_prowler
    night_prowler
    6 years ago
    Quoting Ken in Cairns on 06 Jan 2020 02:00 AM
    Thanks Ken but it’s a custom stainless pipe with no heat shields.
    Looking at doing a transmission service possibly this weekend, would it be worth getting a gasket kit and taking the primary cover off while it’s drained and having a sniff around or generally is the chain the only thing that could be making the noise? The clutch was also brand new less than 6000 kms ago so I’m highly doubtful that could be the issue. It’s got me buggered this one does.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Might be worth a look, even if it just to rule it out.
  • robnicko
    robnicko
    6 years ago
    maybe gear shifter & or  rear brake pedal pivot point bushings?
  • night_prowler
    night_prowler
    6 years ago
    Quoting robnicko on 07 Jan 2020 01:10 AMedited: 07 Jan 2020 01:10 AM
    Checked all of that too, footpegs etc... still nothing!
