Online: beaglebasher
Risers
  • Kris78
    Kris78
    6 years ago
    Hi All
    Hope all have a great new year
    Does anyone know where I can get risers for these style bars either 1" or 2" risers
    Thanks in advance
  • Big Steve
    Big Steve
    6 years ago
    Those type of bars bolt straight to the holes in your top tree so they do not need risers.
    If you want them higher you can get riser extensions that should bolt to the bottoms.
  • Kris78
    Kris78
    6 years ago
    Quoting Big Steve on 31 Dec 2019 11:11 PM
    Thanks I already have them on my bike
    Im just wanting to know if I can get the  1" or 2" risers so I can play around with risers to see if I can make the ride a bit more comfy..
    And where would I get the risers from
  • Big Steve
    Big Steve
    6 years ago
    Quoting Kris78 on 01 Jan 2020 12:52 AMedited: 01 Jan 2020 12:53 AM
    Something like this:
    http://www.dkcustomproducts.com/1-inch-fat-aluminum-handlebar-riser-extensions.htm
    Or 2"
    http://www.dkcustomproducts.com/2-inch-fat-aluminum-handlebar-riser-extensions.htm
  • Kris78
    Kris78
    6 years ago
    Quoting Big Steve on 06 Jan 2020 04:22 AM
    Or 2"
    Big Steve
    Perfect exactly thanks
