Painting a tank
    6 years ago
    Hi, I love the look of this tank (minus Jimi)
    Does ANYONE know how to create the effects?  I'm looking to do this on my Sporty project.
  • Soapbox2627
    Soapbox2627
    6 years ago
    looks like the black base with color applied, then the plastic scrunchy (for each color) pressed on
  • Soapbox2627
    Soapbox2627
    6 years ago
    a little example
    but it may not be
  • Hidiho
    Hidiho
    6 years ago
    Quoting Soapbox2627 on 21 Dec 2019 11:23 AM
    a little example
    but it may not be
    Soapbox is on the money with the technique..
    Black then Silver then cling wrap
    The flowers were done by putting a precut mask (outline and the internal part) onto the silver base and then the tank partially sprayed with Candy Yellow followed by Candy Red (or Orange?), Candy Green then Candy Purple, Then the internal part of the flower was removed then done with the the candies on the internal part of the flower. The outline mask was then removed leaving the silver outline.
    Jimi is a precut mask which was painted black
    6 years ago
    Cheers guys, Sounds easy enough to do so I'll give it a crack over the holidays and see where I end up.
    I mean...what could go wrong; lol
