Superglide shocks on Iron
John.R
6 years ago
Physically they probably will fit with minor effort, they won't be any good though.
John.R
6 years ago
Shocks sprung and dampened for Dyna weight and geometry wont be much chop on a Sporty.
6 years ago
check the bolt hole sizes and make sure they are right. You should be fine with them, just back off the preload a bit.
