Engine noise - TC 88 Fatboy
  • Kato
    Kato
    6 years ago
    Hi
    Ive got an old TC 88 Fatboy with 75 000 kms on her
    All going perfect except having to replace the starter motor . Like could there a be a more difficult to house the starter motor ??
    Anyway ...........when I'm at the top end ( say 75% of the applicable engine range ) when accelerating
    - I get what sounds to be "metallic rattle" vibe up through the fuel tank
    - It  signs off when I back off the throttle
    Im not sure if that's  anything to be  concerned about but Id really appreciate any advice from others on this Forum that might have an idea of what it is and if it requires urgent attention .
    I can assure everyone that is NOT the fuel cap rattling
    Other than that its been a great ride and hope she does another 100,000 Kms and more
    Thanks in advance for any assistance
  • Wideglider
    Wideglider
    6 years ago
    Do you get the rattle whilst revving with the bike stationary?
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Loose heat shield ?
    Best bet is to just go over all the fasteners, good idea to check em every now and then anyway.
    Ken
    6 years ago
    You might be able to recreate in a lower gear at the right rpm....  Loose heat shield, loose gas tank cap?
  • Kato
    Kato
    6 years ago
    Good point - ill do that
  • Kato
    Kato
    6 years ago
    Quoting Wideglider on 07 Dec 2019 10:37 PM
    another good point - only whilst riding and on the gas ( not stationary )
  • Kato
    Kato
    6 years ago
    Quoting tussuck on 08 Dec 2019 01:26 AM
    Its certainly NOT the fuel cap ,...……….nere thought of the heat shield on the pipes ( I'll check that one  )
  • Kato
    Kato
    6 years ago
    Quoting Ken in Cairns on 07 Dec 2019 11:54 PM
    Loose heat shield ?
    Ken
    Yep- particularly the heat shields
    Thanks for the input (most welcoeme )
  • baldy1450
    baldy1450
    6 years ago
    cam chain tensioner ???????
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Gee I hope not, I'm hoping it is something simple for him.
  • Kato
    Kato
    6 years ago
    Quoting Ken in Cairns on 10 Dec 2019 12:54 AM
    Fork ….me too .
    Doubt its the tensioner but i'll have a look in theer plus  need to check on the C Chain sliders . Never did go the gear driven cams route - and last time i checked they were near perfect
