headlight
  • beaglebasher
    beaglebasher
    6 years ago
    Low beam stopped working the other day .   High beam still works.  Havent had a look yet and probably wont get a look until the weekend.
    Just wondering if all I need is a bulb or something else is required.
    I vaguely remember being in there before and thinking it was a sealed unit and the whole lens would need changing but that doesn't sound right.
    Its a 2002 fatboy.   If anybody can confirm its just a bulb I need I can get that before the weekend.  Cheers
  • Old Fatty
    Old Fatty
    6 years ago
    Quoting beaglebasher on 03 Dec 2019 06:55 AMedited: 03 Dec 2019 07:14 AM
    I'm pretty sure it is a standard H4 globe. I'll check for you.
    Mines an '02 fat boy as well and I just checked an old globe. It is a 60/55W H4.
  • beaglebasher
    beaglebasher
    6 years ago
    Thanks for that Oldy. My bike was imported and I think  its still got the original American headlight
    The reason I say that is cos its got Made in USA on the glass and the light has always shone to the right.
    I don't ride at night so its never bothered me but the bikes due for rego soon so I need to get it sorted.
  • beaglebasher
    beaglebasher
    6 years ago
    Just had a look at the headlight.  It must be an original American one cos it says on it  SEALED BEAM
    The female plug has three spade connectors and  the headlight has three male spade fittings.
    So I need a new headlight.  Where can I get one ?
    No doubt somebody will have one in the shed. If you do please contact me.  The bike is a 2002 fatboy but I would imagine other models should fit.
  • steelo
    steelo
    6 years ago
    Time for an upgrade bb. Perhaps hoglights? Talk to Nathan. You won’t be sorry. (Despite some complaints about led lights)
    I could have an original I took off the deuce You can have woc just cover postage. I’ll find out what that is.
    Edit. Just looked. H4
    Separate bulb. Three connectors.
  • beaglebasher
    beaglebasher
    6 years ago
    Thanks for the offer mate.  What is the OD  (outside diameter) of your light?
    I just measured mine after a dozen beers under my belt and its 180 mm.
    I  never ride at night so I don't need a you beaut  light.
    Hang on a minute here .  Youre not a scammer are you?  I have heard about scammers.
  • steelo
    steelo
    6 years ago
    Might not be any good. The deuce light is 5 1/4 (about 14.5 cm) and I think the other standard size is 7
  • beaglebasher
    beaglebasher
    6 years ago
    no worries  man.   cheers
  • beaglebasher
    beaglebasher
    6 years ago
    still looking  for a headlight
  • beaglebasher
    beaglebasher
    6 years ago
    Dropped in to my local bloke after work and he had one on the shelf.
    $65 and if it blows again I can replace the bulb. So youse can all stop looking for your old headlights!
    Thanks Oldy
    Thanks Steelo
