Online: Stuart
Where to buy Amsoil - Synthetic V-Twin 20W-50
  • Whisper
    Whisper
    6 years ago
    Hey guys,
    Just wondering where I can buy some Amsoil Synthetic V-Twin 20W-50, enough for all three holes and filter please?
    Anyone selling this?
    6 years ago
    2 seconds on Google and found their AU website as well as the distributors in AU and NZ.  And at $95 a container - its just not that good!
  • Whisper
    Whisper
    6 years ago
    Thanks mate, yeh I knew where a distributor was ;)  Just was hoping a member was selling and member contacted me and gave me a good deal.
    Cheers for the helpful reply.. again :)
    6 years ago
    Quoting tussuck on 02 Dec 2019 04:13 AMedited: 02 Dec 2019 04:14 AM
    Well, it's the first time, changing to a different oil, I've felt a noticeable gain in HP & TQ ( seat of pants ) also it's running a lot cooler. the Penrite HPR30 20W 60W Dino  must have been causing friction or the AMSOIL v-twin 20W 50W is good.
    when I was using the oil Redline make for Harleys, I did not notice a gain in feel , but it never ever needed to be topped up. and when looked in the motor it had been doing its job. plus the Redline was in a Twin Cam carb that was only 95inch but I reved that motor to 7,200 regular at drag strip.
    but the redline engine oil was expensive !! & the AMSOIL V-Twin is expensive !! but the way it's performing in feel & cutting heat down, indicates to me a reduction in friction. I'll stick with it.
    6 years ago
    Quoting Krash Kinkade on 02 Dec 2019 10:21 PM
    I may bite the bullet and give something else a crack.
    Although I do about 4 oil changes a year so for me things add up quickly and even with a super oil like Amsoil I would still change it out at the 5,000km service mark I use (i would not be keen on extending it either).
  • Whisper
    Whisper
    6 years ago
    Thanks mate,  I have only heard good things about the oil. I also like that it can go in all three holes :)
    Hangin to get the change done.
    6 years ago
    Quoting tussuck on 03 Dec 2019 12:52 AM
    can understand!
    6 years ago
    Quoting Whisper on 03 Dec 2019 08:03 AM
    Hey Mate, I'm on a sporty, so I don't have a choice on gear box oil as GB & primary on sporty are combined.
    my recommendation is for the gear box use Redline Heavy shock proof, you will feel the improvement!! it is also a one off you don't need to change it again.
    I have not tried the AMSOIL V-Twin 20W 50W in the primary, but it says you can use it there too. I've got Redline MT in primary & GB ( can't use heavy shock proof in primary as would load the clutch up ) when I had a twin cam I always used valvoline AUTO trans fluid type F and it worked fine clutch loved it.
  • Whisper
    Whisper
    6 years ago
    Sounds like a good idea man, I have a 2010 FXSTC with 60k on the clock, I don't ride it hard but am wary of the k's creeping up so wanted to treat it with the Amsoil. The redline shockproof sounds awesome, I just read a bit about it and I think I will go that way.
    My mate said 60k is nothing for my engine type so hopefully the good fluids will help extend it's life.
    Just reminded me to get a service manual lol, don't know how much goes into the GB.
  • WideglidingNZ
    WideglidingNZ
    6 years ago
    Quoting Whisper on 03 Dec 2019 10:10 PMedited: 03 Dec 2019 10:12 PM
    Should be 1 quart (not quite a litre)for the GB and yes the R/L shockproof comes in a quart bottle
    6 years ago
    The best tool for a long engine life is regular oil and filter changes (and to not live at max rpm -  actually program my RPM cutout lower by 1500rpm as a safeguard)
    6 years ago
    Can someone drop me a note about a supplier in melbourne?  I'm looking at either a 4 litre or even larger container of AMSOIL V-Twin 20W 50W
    6 years ago
    Yeah he is the local distributor I think.  And at that price I'll stick with harley oil as I cannot afford $420 a year JUST for oil in the Sporty.
  • Whisper
    Whisper
    6 years ago
    Quoting WideglidingNZ on 03 Dec 2019 10:52 PM
    Thanks for that info mate :)
