Online: pat
2017 Breakout dead - SOLVED
  • luz
    luz
    6 years ago
    Hi Guys.
    I have a 2017 Harley Breakout with key-less start and alarm with siren.
    Was riding and engine light came on but bike ran normally and arrived at destination so turned the bike off. Next time I tried to start the bike, it was like the alarm FOB was not present and the siren went off. I mucked around for so long the siren battery went flat. I went to look up the alarm over-ride instruction which I found.
    Came back to the bike but now the dash is dead (it wasn't dead before) so I can’t enter the pin. Battery voltage is normal and fuses checked good.
    Have left if hooked up to a charger but the alarm back-up battery fails to recharge.
    If I lift the bike off the side stand the blinker flash with no siren, Even with FOB present.
    If I pull the fuses out, nothing happens, normally the alarm would go off as the FOB is not present, this is now not the case.
    The only evidence the spedo is not dead is the alarm red light is flashing, nothing else ever works.
    My initial thoughts were the ECU, BCM or something to do with the immobilizer.
    Any help would be appreciated.
  • WideglidingNZ
    WideglidingNZ
    6 years ago
    Have you checked the fob's battery and the alarms 9 volt battery?
  • luz
    luz
    6 years ago
    Quoting WideglidingNZ on 01 Dec 2019 05:27 PM
    Thanks for taking the time to reply WideglidingNZ.
    Yes. The FOB battery is GOOD.
    The alarm's 9 volt battery was good but is now FLAT because of me mucking around with this defect.
    Bikes main battery is GOOD.
    "I think" as the bikes main battery is good, the bike should still start normally and the alarms 9 volt battery should charge once the bike is ridden.
    6 years ago
    Umm not sure why the engine light came on first. You cant get any error codes up via the speedo?
  • luz
    luz
    6 years ago
    Quoting paulybronco on 02 Dec 2019 02:10 AM
    No, the speedo is always dead nomatter what I do with the start switches. The only evidence the spedo is not dead is the alarm red light is flashing, nothing else ever works.
  • luz
    luz
    6 years ago
    Quoting luz on 01 Dec 2019 09:21 AMedited: 20 Dec 2019 03:55 AM
    Hi Guys.
    Changed the R/H Handle Bar Switch Module P/N 71500297 and got power back to the speedo to read the codes.
    The only code was "LOST COMMUNICATION WITH BCM" U0142.
    Erased code.
    Started bike and all is normal. Even the alarm and alarm backup battery is working normally. Unbelievable
  • Baloffski
    Baloffski
    6 years ago
    Hey Luz, thanks for the follow up man, is appreciated as may happen to one of us, and there ya go, I'll B fooked......
    6 years ago
    There you go, good result
