Online: beaglebasher
Need help please - 2010 FXSTC Breather hoses - new air-cleaner.
  • Whisper
    Whisper
    6 years ago
    Hello and thanks for your time. :)
    I have a 2010 FXSTC and I am trying to learn as much about my bike as I can, so far it has been a great experience.
    I decided to replace my S&S teardrop air-filter with a new Arlen Ness 90 degree filter setup - namely: Arlen Ness 81-000 Air Filter 90deg Big Twin'93up w/CV Carb or w/Dephi EFI (exc TBW'08up) Black.
    The issue I am having is, the new filter setup has gone one smoothly but I am left with the two breather hoses that were attached to the bracket bolts in the head.
    Can I simply remove the 'T' join (there are two hoses one to each bolt from a T joint) and make one single hose to vent into the Atmosphere?
    Any suggestions are greatly appreciated as I do not know what to do from here :)
    Check out the attached photo.
    Whisper
  • Whisper
    Whisper
    6 years ago
    I just found this info:
    Our Monster Sucker 90° air cleaner kit features a massive forward facing filter design and our patented hidden breather backing plate for maximum performance gains
    Our patented hidden breather technology are o-ringed at the heads and exist out the mouth of the injector/carb to provide efficient engine breathing, eliminating the need for any external hoses or hardware
    Does this mean I can simply remove those hoses?
  • gidgi
    gidgi
    6 years ago
    to put this into perspective for you , Harley engines breath from both heads  they normally flow into the backing plate of the filter & then the fumes / excess oil get  sucked into throttle body & back into the fuel/ air mixture, excess oil can contain within the filter  & eventually drip , this is something that  most people fix by re routing the breather via hoses from the heads to a T piece & into the atmosphere or a catch can. I have put a small chrome filter on the end of "said hose" this is called External breathing  with out seeing your set up it sounds like that`s wot is on there now ..Hope this helps
  • mickle
    mickle
    6 years ago
    Get rid of the hoses, that breather is breathing through the mounting bolts directly into the new breather, did you notice the bolts are hollow?
  • Whisper
    Whisper
    6 years ago
    Thanks heaps guys, just removed the hoses and it breathes through the backing plate, thanks again :)
    6 years ago
    I like the way the filter has a hole facing forward to catch the rain better and provide internal engine cooling....neat.
  • mickle
    mickle
    6 years ago
    Quoting tussuck on 02 Dec 2019 01:30 AM
    Who rides in the rain?
    6 years ago
    Quoting mickle on 02 Dec 2019 01:31 AM
    Thats the problem!  Way too many snowflakes in this generation!  I ride rain or shine, but I have to as my bike is my commuter vechicle.
  • Whisper
    Whisper
    6 years ago
    Yeh, I don't ride in the rain, but Arlen Ness make great stuff and as it sits, is water resistant if you get trapped in the rain, no need for a sock :) - the forward facing hole is not directly open and cycles air back into the filter. I would recommend another filter if you are riding in the rain a lot - or a car.
