Horn relocation
  • Phatty
    Phatty
    6 years ago
    I've taken tha tank of my 09 Fatboy just to have a look and do a cleanup, I'm thinking of relocating the cowbell horn to the front of the bike ( Where the hole is at the front of the frame ) See pic 2 , Does Harley or anyone make an extension for the wiring ?
    I'm going to find another mount and modify it so it won't have the horn mount between the heads.
  • Grease Monkey
    Grease Monkey
    6 years ago
    2016-17 lowrider S horn and extension cable will sort you out, that's what I used on my 2016 slim S to move the horn there.
  • Phatty
    Phatty
    6 years ago
    Quoting Grease Monkey on 01 Dec 2019 06:56 AM
    Thanks Mate, I'll go in tomorrow and get get that kit.
  • Phatty
    Phatty
    6 years ago
    Quote source removed.
    Just wanted to clean it up a bit, Got a set of Accel Stealth Coils coming from the States so the original Coil will go also as will the bracket that holds the original coil.
    6 years ago
    very very nice.... BUT fucking expensive to just hide the coil.
  • Phatty
    Phatty
    6 years ago
    Quoting tussuck on 01 Dec 2019 08:25 AM
    Got a Mate in the States who runs a Harley Repair shop, Cost me delivered here $200.00 Aus Brand New.
    He's been running a set for over a year and reckons they are Gold.
  • Phatty
    Phatty
    6 years ago
    I moved the horn to the front, Sparky mate made an extension for  the wiring and it all works.
    Instead of cutting the engine mount between the heads I cut the horn mount on the Mill and put it on, It looks Ok.
  • shaggy
    shaggy
    6 years ago
    Looks good. Just make sure the front fender doesn't touch on (full) compression.
    I moved mine to a similar location  on my FXR and it fowled on the fender under heavy braking (have since moved it back a bit).
  • Muzza Wa
    Muzza Wa
    6 years ago
    Quoting shaggy on 04 Dec 2019 02:10 AMedited: 04 Dec 2019 02:11 AM
    Hi, I have done the exact same thing, and first attempt was similar to yours and I received a nice scratch in my fender for my trouble, second attempt was better, lowered the placement with a bracket so that the hooter is recessed in to the gap between the frame and the ABS module. I’ll post a picture.
  • Muzza Wa
    Muzza Wa
    6 years ago
    Quoting Muzza Wa on 04 Dec 2019 06:28 AM
  • Phatty
    Phatty
    6 years ago
    Quoting Muzza Wa on 04 Dec 2019 06:34 AM
    That looks much better mate, I'll make up a bracket do as you did.
    One other thing the Clamp I took of the fuel cross over line had a pinch clamp on it, Where do buy those and the the tool to crimp it.
  • Muzza Wa
    Muzza Wa
    6 years ago
    Quoting Phatty on 04 Dec 2019 07:54 AM
    I did not! The cost of the tool and the rings were more expensive than the crossover pipe I bought from HD. Now when I remove the crossover line I buy a couple of $5 seals and reuse the pipe with its screw fittings.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    2 dollar hose clamp sorted me out.
  • Phatty
    Phatty
    6 years ago
    Quoting Ken in Cairns on 05 Dec 2019 01:41 AM
    Did just that Mate.
