Online: pat
Photos of Crankcase breathers routed into exhaust
  • Robbo_Townsville
    Robbo_Townsville
    6 years ago
    Hi, I was talking with a shop the other day about a catchpot setup and mentioned about routing them downstream of the oxygen sensors. Anyone heard of this before? I suppose it would provide a vacum effect and the crap that would normally go to the intake would just burn off in exhaust headers.
    Well got it done and happy with finish and maybe by seat of the pants little more oomph.  Bloody pics on there side, dunno computers.
    6 years ago
    you get reversion in da exhaust pipe , esp in a single pipe per cylinder , cheers
  • Robbo_Townsville
    Robbo_Townsville
    6 years ago
    Quoting daddyracer56 on 12 Nov 2019 06:55 AM
    So I have a 2 into 1 D&D Fat Cat exhaust. Do you reckon she’d be a no go.
  • Daggs
    Daggs
    6 years ago
    Quoting Robbo_Townsville on 12 Nov 2019 10:07 AM
    Just go to atmosphere
    6 years ago
    Quoting Daggs on 12 Nov 2019 10:33 AM
    Agree , its a greenie save the lesbian whales solution to burn off the crap
    6 years ago
    Quoting paulybronco on 12 Nov 2019 10:59 AM
    +1 or into a small catch can - easy enough to make with some old exhaust pipe.
  • Robbo_Townsville
    Robbo_Townsville
    6 years ago
    Got it done and uploaded some pics.
  • rodrocket
    rodrocket
    6 years ago
    I mentioned this some time ago in another thread about a Vac-U-Pan style breather I will do it on mine when time permits
    I did notice that on your system there is no one way valve, I think its a must you can use a single one in the line running down to the pipe from memory S&S make a valve suitable
    when I get time I will find the valve that I looked at using and post up a part number
  • Robbo_Townsville
    Robbo_Townsville
    6 years ago
    Cheers Rocket. I would have thought the need for the check valve would be minimal as the system provides a venturi effect. Gas would follow the path of least resistance, but on the other hand I guess you have pistons going up and down providing I guess a sucking effect on the down stroke.  Is that what your getting at?  The bike feels to me like it revs a little easier, slightly different note at idle. I'm thinking about doing it to my M8 Tourer which I have had to go back to the Screaming Eagle Air Cleaner ( from the Arlen Ness Big Sucker) due to oil down the side of panniers on a long hard run.
