HD OEM Risers 6" Chrome and Corrosion
Turtle
6 years ago
Anyone have any issue with risers bought from ya local HD dealer where the chrome started blistering? I bought a set of 6" risers for the 2018 FXLR and within 3 months they started pitting or blistering. I took them back and got replacement under warranty only to have the second set do the same. The manufacturer supposedly told the dealer it was a maintenance issue. If it was then why isn't the other chrome from OEM doing similar!
Ken in Cairns
6 years ago
I have the 4 inch curved ones, and chrome is mint still, going on two years old now.
Turtle
6 years ago
A mate has similar 4" pullback risers and no problem.
Turtle
6 years ago
I got a second set of risers same brand, distributor and style and same issue. HD Mackay offered a refund which I accepted. The folks [including the HD Mackay] that have looked at the risers have all agreed it is pour quality chrome work on them, except the distributor who says it was maintenance issue. I now have a borrowed set on the bike that were bought around 2000 and they show very little wearing or chrome peel. Thanks, Noddy.
keith
6 years ago
Had similar on my deluxe, more comfortable riding long distance. No issues with the chrome.
6 years ago
Typical Harley for blaming others for sourcing shit components. The ACCC needs to move on to the bike industry to start pulling a few manufacturers into line with gettng them to abide by the consumer laws of the land.
