Online:
B0nes
tail light 4 pin thingy?
jc
6 years ago
I need one of these for my Sportster but dont know what they are called. Tail light thingy connector??? Where to get from? Thankyou Jacqui
Neale
6 years ago
Try a dealer.
You might be surprised and find out it ain't that dear.
You'd have to be lucky to get one from a wreckers.
That's all I got.... Sorry.
berserker
6 years ago
Hi jc I think this is what your after:
73154-96BK is the part number. just plug it into Google it looks the same as the one in my dyna judging by the photo. The dealer will have it but they'll probably have to order it. For any parts related queries, give this website a go:
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
Once you find your bike model in the list it gives you all the part numbers. From there either Google the part number and buy online or just tell the dealer and they will order it for you. Hope this helps
6 years ago
73154-96BK SOCKET HOUSING, 4-way (black) XL1200C, XL1200L, XL1200R, XL883, XL883C, XL883L, XL883R
73156-96BK SOCKET HOUSING, 6-way (black) (2) XL1200C, XL1200L, XL1200R, XL883, XL883C, XL883L, XL883R
73191-96 SOCKET TERMINAL, 16-20 awg (as required) XL1200C, XL1200L, XL1200R, XL883, XL883C, XL883L, XL883R
Humbug
6 years ago
Quoting berserker on 07 Nov 2019 11:16 AM
Thanks for the link berserker it will come in handy.
jc
6 years ago
Thanks all for your help
6 years ago
Plug your VIN in here and you have free access to the parts manual for your bike...you can even download the PDF.
https://serviceinfo.harley-davidson.com/sip/
jc
6 years ago
Cheers tussuck i give it a peruse. Thanks
