Online: B0nes, tussuck, Hilly, Wanderer57
Motorcycle lift table
    6 years ago
    Hi, I have searched but a lot of the threads are old with broken links.  Has anyone bought or know of these bike lifts?
    https://www.wholesalesuperstore.com.au/motorcycle-lift-table-hydraulic?gclid=CjwKCAjw0vTtBRBREiwA3URt7pSuaEEymfMJQye83t-CqEgDczGhHSeNKKS_EWPEerF9NCxBLPOjNBoCXDUQAvD_BwE
    I would like to use it fir a Sporty and FXR
  • John.R
    John.R
    6 years ago
    Yep, I have one. Awesome bit of kit, especially for the price. There'll be pics in my threads.
    Dad has one and uses it for his Ultraglide with no dramas.
    I'd grab the little scissor lift for the frame too
    6 years ago
    Cheers....I just downloaded some plans for a very popular one on the Internet as an exercise in costing the raw materials....  I got up to $255 in raw steel costs and that is stopping short.  I recon the material costs alone for the DIY are about $350 - $400 and then there is labor on top.
    All in all it makes a compelling case to buy the wholesalesuperstore one (even if it is a kit its still a 'complete kit')
    I'll head down that path...
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    If the delivery cost wasn't as high,  I would consider one, but delivery is nearly $400.
  • John.R
    John.R
    6 years ago
    Delivery is only $140 off of ebay.
  • Spook
    Spook
    6 years ago
    I have an IB Bike Lift. Not sure about price but the product is great for my Road King. EDIT: Oops...now $400.00
    6 years ago
    I have an IB style unit, but I’m an old fart now so want a table system for the height and better stability
  • Spook
    Spook
    6 years ago
    Quoting tussuck on 03 Nov 2019 11:21 AM
    Yeah, I can understand you have nowhere to put your beer with the IB unit.
    6 years ago
    Not fair!   This is Melbourne so its a Latte!
  • Daggs
    Daggs
    6 years ago
    Yeah I have one similar from eBay, good lift but I did a few mods to it to make it better. Good for the price though, mine is in use everyday
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I missed the cheaper option  @ $252.
    John R what city was that $140 too.
    The price I quoted was from the linked supplier in the OP.
    6 years ago
    Its $160 postage to Melbourne.  Be handy if they had a local pickup point down here.
  • Tin Basher
    Tin Basher
    6 years ago
    Hi, just something to look at is the weight rating, the cheaper ones 450 kg have a C- section or a pressed S- section frames and the more expensive 600kg are made from RHS.
  • Big Steve
    Big Steve
    6 years ago
    Quoting tussuck on 04 Nov 2019 12:03 AM
    There is a mob in cambelfield that seels them, I paid about $1100
    That sale price is damn good.
    6 years ago
    Okay, So this is shear friggin genius!  A small bike lift cut in half and extended!
  • Baloffski
    Baloffski
    6 years ago
    Quoting tussuck on 10 Nov 2019 09:10 AM
    Hey Tussock, that is a dam good idea, I have the same lift I bought new for $50 as the jack didn't work.That was about 8 years ago, so might be time to extend.
    Then just need some steel, and then a welder and a book on how to weld, half proper..Agree Genius.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Son of a bitch! It's not real high but if you can make it longer I bet you could make it a bit higher within reason, that's pretty darned ingenious.
    6 years ago
    Quoting Baloffski on 10 Nov 2019 10:05 AM
    No need to weld, just use grade 8 bolts, but obviously welding is best.
  • Baloffski
    Baloffski
    6 years ago
    Quoting tussuck on 10 Nov 2019 11:47 AM
    Well I'll be dam-ed, am anyway, but drill and bolt is my middle name.
    Am an old rigger from way back, building towers, masts, or any structure, which sometimes needed drilling and bolting up at heights.Have shitload of bolts, nuts washers in stainless.That's a pearler.
  • Damo222
    Damo222
    6 years ago
    BRILLIANT!
