Online: Stuart
Heat Shield Rattles and Squeaks
  • leachy
    leachy
    6 years ago
    Hi All,
    Just wondering if anyone else experiences the same issue. Its the stock heat shields on the bike always seem to come loose and rattle. The bike is fitted with a SE muffler so its a 2:1 setup. Any advice on how to fix this, ive tightened them to the point where it feel like the nut is going to strip (it hasnt), but it very annoying and sounds really bad at the same time.
    Thanks
    Leachy
  • JFE
    JFE
    6 years ago
    Could the vibration be coming down from the header connection to the cylinders or frame itself? My Fat Bob’s 2-1 system needs to be tighten there as it’s pretty heavy and over time the rattles add up.
  • leachy
    leachy
    6 years ago
    Ill have a look at that. But the connection point to the SE muffler at the connection point with the heat shields is very ordinary looking. You would expect seeing its HD supplied that they would at least attempt to make it look slightly right.
  • Big Steve
    Big Steve
    6 years ago
    Whenever one of my headshields comes loose its usually time for a front engine mount.
  • leachy
    leachy
    6 years ago
    Quoting Big Steve on 24 Oct 2019 03:22 AM
    Bikes only 5500kms old.
  • JFE
    JFE
    6 years ago
    Quoting leachy on 24 Oct 2019 03:54 AM
    I had a front mount replaced under warranty at 8000 km’s.
  • leachy
    leachy
    6 years ago
    The front mount looked just fitted a sputhie stabilizer to it. But how do you tell if its stuffed anyway.
