Online: Hilly, Merv
Replacement Neck sections
  • Shovelhead80
    Shovelhead80
    6 years ago
    Hi to everyone & its been a while since I posted a question or comment.
    I'm currently looking for a replacement neck for an older shovel frame I picked up at a swap meet.
    Problem is its fairly busted up & was bought as a potential Chopper / bobber /resto build.
    The rest of the frame is recoverable due to the level of damage & age of the frame. (earlier than 1980 stat write-off doesn't apply)
    The neck has sustained damage & the numbers are missing. i.e. chunks of metal gone.
    So I heard there was reproduction necks available but all the units I've seen on eBay & various sites are like US$350 & up. Some at $450 plus extra there's the expensive shipping out to Australia., jigs , welding, engineering,etc.
    For a little extra I can buy a complete frame made locally or an imported aftermarket USA frame
    Problem is I want an older frame so I can run under older rego laws. A new frame would mean new build laws, Not Shovel laws, if you get me.
    I'm hoping someone out there has or knows of a frame or parts of a frame that I can purchase & get shipped to me.
    Preferring a pre-68 to a later. However I'm interested in any options that come to me.
    Either responding to this post or by PM will get my response.
  • STROPP
    STROPP
    6 years ago
  • Uncle Chougs
    Uncle Chougs
    6 years ago
    Hi "Shovelhead80",a quick question...to me it sounds like you have a Shovel engine laying around awaiting a project...
    Would you be doing the neck replacement job yourself? Have you got a close up picture of the frame neck area and would you be able to post a front view of the frame(if possible level)?...
    I might have some ideas if you are interrested..
  • Shovelhead80
    Shovelhead80
    6 years ago
    The frame in question is buried at present, but I was able to have a friend look at it.
    All it really needs is the cast neck section replaced.
    However I am open to recycling the frame as a modified original.
    Looking to move the neck section forward & up with a custom (&reinforced) head-stem section, along with dropping the seat area but maintaining rear suspension.
    That is unless someone out there has a Shovel suitable, plunger suspension frame they are willing to do a swap with.
    A repairable original frame should be able to pull some money but the Plunger rear frame may be a question asked but never replied to.
  • Far Canal
    Far Canal
    6 years ago
    Love the pillion seat on your bike!
    A picture paints a thousand words, hilarious.
  • Uncle Chougs
    Uncle Chougs
    6 years ago
    Santee plunger frames looks pretty cool!not sure if they still manufacture them though...I was going to suggest you to get a local engineering shop around your way to manufacture a neck using your existing one as a template or have a quote,but it also might be an idea to check out those guys in the US,don't know them personally but they seem to have some good and affordable gear for a custom build ;
     http://www.bitterendchoppers.com/FramePartsPg1.html
  • Birtyyy
    Birtyyy
    6 years ago
    If you're looking for replacement castings check out hardtailchoppers.com
    John does standard stuff or also raked versions / custom stuff. He's based in the US so the exchange rate is painful but I've been following his work for a while and it's top notch.
    Also drop seat castings check out Jeff Cochran at speedkingracing.com
  • Shovelhead80
    Shovelhead80
    6 years ago
    I did the calculations regarding getting a neck from the US.
    It just isn't worth it.
    In US$ it's approx the following. Neck $350-475, Shipping $50-100, Total $400-575 = A$600-900
    Welding (incl jig & rego report) =A$200-350 & it could be more.
    Grand total A$800-1300 estimate.
    For just a little more I can get a good frame or an engineered custom.
    The exchange rate & customs kills off any real hope of doing a job at a reasonable price.
    Looks like it's going to the rear of the shed & will wait until I can either afford it or can get hold of the parts needed.
    6 years ago
    i know a fella here in Sydney that could help you out
