Online: Aiwoz65, Hilly
Need to move the pegs on a 2004 springer fxsts
  • Mel
    Mel
    6 years ago
    Hi, I’ve just bought a 2004 springer and need to move the pegs back at least an inch. Don’t quite want it mid range but can’t ride it comfortably the way it is as using my toes and stretching. Any ideas greatly appreciated
  • Roo Ted
    Roo Ted
    6 years ago
    Hi Mel. I have the same problem on my '03 Dyna. Tried modifying the mounts & controls to bring everything back but wasn't happy with the result. Now looking at having the seat reshaped to sit me forward instead.
  • Grease Monkey
    Grease Monkey
    6 years ago
    What Roo said about the seat got me thinking, Harley make a reach seat that could maybe improve things a bit, part number is 52444-04A, Google it up and have a read of the blurb, just might be the answer you are looking for.
  • Roo Ted
    Roo Ted
    6 years ago
    Don't think they make a reach seat to suit the '03, at least I couldn't find one on the HD site to suit that model. If anyone's got one I'd happily swap it for beer money.
  • Grease Monkey
    Grease Monkey
    6 years ago
    According to Harley the same one will fit your 03 Roo
  • Roo Ted
    Roo Ted
    6 years ago
    Oh ok. I'm only seeing soft tails, no Dynas. One size fits all? Really?
    Would fit Mels bike though.
  • Mel
    Mel
    6 years ago
    Thanks guys. Mines a fxsts so that covers it but still not sure that’ll fix issue as don’t really want my feet so far forward.
    Reach seat looks like an option though so thank you
  • Grease Monkey
    Grease Monkey
    6 years ago
    Sorry Roo, didn't realise you had a Dyna, no mate, that won't fit
