Online:
FONTANA302
Building a bike
Building a bike
inmate
6 years ago
Hey Legends. Long story short, I was rear ended pretty hard on my 13 breakout. I'm fine, however I'm looking into buying the bike back from insurance as an ICV project if I get a good price.
Would just like to know about the Kraft tech frames, best one to suit my parts etc and what's involved after the bike has been assembled etc. I'm very mechanically minded though have not done a project this size before and csnt wait to get started if it's a reasonable idea.
Also what parts of the harley I can and cannot use
Kind Regards
Inmate
6 years ago
Have been down this rd myself but with evo softail ,
As for a kraftech frames there great better made than a Harley frame in my opinion
Full steel not a combination of cast iron / steel tube in evos any way
As for later frames no idea but for what it’s worth if you’re getting a decent payout
Let them have the bike and buy a new or newer bike depending on $$$ you get
Anless you have that much invested in the wreckage already As much
As you think the bike looks pretty salvageable it will be bent in places you can’t see
Buy eye and till you start bolting stuff up on the new frame Which can turn
Into a money pit which you won’t get back at all , and normally the insurance
Will want a good dollar for it , but if you’re up to it and not in a rush
Go for it I’ve got the same habit turning crap into a gem You do see a lot
Of this same thing on gumtree guy’s doing it or not finishing it
than expecting wha5 they have invested in back example $20k
In a bike which is not complete or regoed when can get one on the road for
Between $18k to $22k example but like said if it’s a budget build
And you get it back for a good price bring on the rattle can paint job every day
Work hack lol
Wideglider
6 years ago
As
The above from perthhog is true.
Don't know your level of experience but it can be the brackets, axles, bolts etc on the guards, triple tree, tank & other fittings that will not quite line up - can drive you nuts
when trying to build a bike.
