question for the engine builders
  • bigbill
    bigbill
    6 years ago
    Any advice would be appreciated,
    I am thinking of buying below for my 2010 dyna fatbob 33000K's on the clock
    Cylinder heads are 89cc this will give me  10.2:1
    I have vance and hines big shots
    S&S Cycle Super Stock Cylinder Head KitS&S Cycle Super Stock Cylinder Head Kit 89cc
    #434-573
    S&S Cycle 4? Bolt On Sidewinder Big Bore Cylinder and Piston Kit Wrinkle BlackS&S Cycle 4? Bolt On Sidewinder Big Bore Cylinder and Piston Kit Wrinkle Black
    #912-843
    S&S Cycle Quickee Pushrod KitS&S Cycle Quickee Pushrod Kit
    #445-248
    S&S Cycle Throttle Hog Throttle Body 66MMS&S Cycle Throttle Hog Throttle Body 66MM
    #975-282
    Feuling Injector 6.2 g/sFeuling Injector 6.2 g/s
    #176-619
    S&S Cycle Premium Hydraulic Tappet Set with HL2TS&S Cycle Premium Hydraulic Tappet Set with HL2T
    #711-936
    BDL Ball-Bearing Lockup Clutch Conversion KitBDL Ball-Bearing Lockup Clutch Conversion Kit
    #630-0099
    S&S Cycle 635 H.O. Gear Drive Easy Start CamsS&S Cycle 635 H.O. Gear Drive Easy Start Cams
    #160-971
    S&S Cycle Roller Rocker Arm SetS&S Cycle Roller Rocker Arm Set
    #247-093
    S&S Cycle Stealth Air Cleaner KitS&S Cycle Stealth Air Cleaner Kit
    #975-264
    S&S Cycle Rocker Arm Shaft SetS&S Cycle Rocker Arm Shaft Set
    #432-828
    Dynojet Black Power Vision TunerDynojet Black Power Vision Tuner
    #210-751
    Dynojet Autotune Kit for Power VisionDynojet Autotune Kit for Power Vision
    #176-305
    S&S Cycle TC3 Oil PumpS&S Cycle TC3 Oil Pump
    #179-299
    S&S Cycle TC3 Cam PlateS&S Cycle TC3 Cam Plate
    #179-304
    6 years ago
    Just at a glance , use your stock heads and get them ported , aim for 10.5 comp.
    Steer clear of the 635 cam, Instead look at the s&s 585. Forget about the new cam plate and pump unless yours are worn .
    6 years ago
    Quoting speedzter on 09 Oct 2019 09:05 AM
    Agree with speedzter on all points
  • bigbill
    bigbill
    6 years ago
    Why do you say to stay away from the 635 I would think that with the 66mm intake it will flow really well
    Below is from S&S that's why I chose the 635.
    585: Designed for 88 to 95 CID engines with compression ratios from 9.7:1 to 10.5:1 and 100 to 124 CID engines from 9:1 to 10:1 compression. Provides massive horsepower and torque increases starting at 3000rpm and holds steady all the way to redline. 3500-6000 rpm for 88" - 103" engines and 2500-5500 for larger engines.
    635HO: This is the cam set for the rider looking for maximum horsepower. With .635" lift, your engine can really breath. They’ll work even better when you have your cylinder heads CNC ported in Step 4. High lift S&S valve springs are required.
    I live in Qatar at the moment so getting my heads ported is not possible.
    I plan to change oil pump and cam plate as it it gets HOT here the few extra PSI of oil pressure will help, I do have a fan assisted oil cooler already.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Late to the party but been some good points passed on, I'm no builder but a few  more things to mull over, those 635's have low 40's intake close and a high TDC lift so you would need to make sure of valve to piston and valve to valve clearances, the comp could prove difficult to tune where you are, a 110 (as that's what I'm thinking you are going to) can only pump so much air, a 58mm TB and 5.7 injectors is all you would need, the 5.7's make fine tuning easier, you could buy ported heads on line to suit a cam that works for your riding style, nothing really needs to be out of one manufacturers catalogue, you could even talk to a real builder and get the lot all matched up and ready to bolt on with a couple of unknowns, but you were going that way already and even those can be overcome with some patience and technical communication with the machinist.
    Blabbering.
    Out.
