Online:
Wanderer57
Wide glide 21” front rim fits dyna streetbob???
Mkmdyna
6 years ago
Hi all just want some advice on my my15 dyna streetbob.
I’m wanting to put a 21” front rim on it I have heard that it’s possible a wide glide rim might fit can anyone help me with yes or no or things to watch out for it will it even fit can it be done thanks guys
Sparra
6 years ago
Pretty sure a Wideglide front end is wider than a Streetbob front end so a Wideglide hub won't fit..
Mkmdyna
6 years ago
The gap seems to be the same just the forks are smaller on the wide glide
Ratbob
6 years ago
Need to be clear, are you planning on lacing on a WG rim to your Streetbob hub (which I think your post suggests) or do you want to use a WG wheel?
Mkmdyna
6 years ago
Hi mate I’m probably going to get a complete wheel
Mr.Mow
6 years ago
Quoting Mkmdyna on 21 Sep 2019 10:02 PM
I’d just jam a new rim on the existing hub, replace the spokes with stainless while you’re at it, lot less screwing around.
You’ll want to check tyre radius as well, not sure how replacing a rim may affect the abs sensor, do they rely on the rolling radius?
