Intercom headset plug in type
Robbo_Townsville
6 years ago
Hey guys, I’m after one of the clips that goes inside the helmet which allows you to then screw the mic to it. Harley can’t sell just the clip
steelo
6 years ago
Sorry to hear RT. Have a look in the box (if you still have it) they come with 2 (for diff profile helmets)
EDIT: Found a spare. They all appear the same size.
PM me your address and I'll send it to you FOC with a couple of OEM Phillips head screws
Robbo_Townsville
6 years ago
Hey cheers bud. Would you believe I didn’t keep the other clips that came with them after I installed them on both helmets.
