Online: WideglidingNZ
handle bars
  • weasel 76
    weasel 76
    6 years ago
    hello all has any one fitted 2017 street bob handle bar and risers to a 2016 wide glide will it fit or not thanks
  • Mr.Mow
    Mr.Mow
    6 years ago
    Quoting weasel 76 on 07 Aug 2019 11:31 AM
    I’ve got 8” Biltwell chumps and 1” risers which are similar in size, the upper brake line is stretched pretty tight, the clutch cable reaches ok and wiring all went though ok. But I suspect the street bob bars may be that tiny bit taller.
  • Big Steve
    Big Steve
    6 years ago
    FYI A set of street bob cables is about $200 so I would just run street bob Throttle/Idle, clutch and brake.
    Brake might be the only question mark given the wideglide has longer forks
  • Tarvis
    Tarvis
    6 years ago
    Quoting Mr.Mow on 07 Aug 2019 12:54 PM
    hey Mr. Mow, just wondering where your sissy bar is from. I'm looking for something similar.
    And the seat while you're at it ;)
    Cheers,
    Tarvis
  • Mr.Mow
    Mr.Mow
    6 years ago
    Quoting Tarvis on 12 Aug 2019 01:58 AMedited: 12 Aug 2019 01:59 AM
    Cheers,
    Tarvis
    Sissybar is from kickerparts in the US, they’re all custom made, I did need to modify the mounting holes to fit though.
    Seat was from easyriders in Japan, super comfortable, have done 10hr days on it.
