2012 Fatbob axle spacers
Ken in Cairns
6 years ago
Anyone know off hand how long the front and rear internal bearing spacers are ?
I'm at work and want to machine up a couple of bearing press plates with a spigot one each to hold the spacer tube square.
Cheer
Ken
6 years ago
Gotta ask why the bearings hold the tube square , disc side bearing in first
Than flip over the wheel slide tube in than home the bearing to it
I’ve only ever eyeballed it as there normally bigger I’d than the
Bearing I’d
Ken in Cairns
6 years ago
Just thought it would save a bit of rooting around with the axle spacer. Can just press the bearings in as per the correct method and the spacer will be in the right position for the axle to go straight in, no backing off the press plate, adjusting the tube, rinse and repeat. I was pretty sure the tube is a bigger ID than the axle OD. but you have confirmed it.
It is just an idea, if it doesn't pan out I can lop off the spigot amd just use the press plates.
