Online: Hilly, dicko
Go pro mounts
1/3
  • binnsy
    binnsy
    6 years ago
    I use a go pro mounted to the bars when riding and it works a treat, can spin it 360 degrees for some side or reverse action, good fun when riding with others. Now my problem is when I put the wind splitter screen on the bike, this is a rare occasion, but when its on it takes up half the shot on the camera.  I have looked around for something else but haven't really found anything Im completely happy with.  RAM mounts come close with some of their mounts which I actually use for mounting a Power Vision.  It will sort of allow me to mount the camera to the bars and extend it sideways a little to get around the screen.  Not ideal, as I want to keep the mount as short as possible to keep vibration to a minimum.  Short of mounting the camera via a mount stuck on the screen, again not ideal, has anyone got any ideas to get around this.  Thought there might be some go pro experts out there ?? Dont want to mount it to my helmet and look like a complete knob.
    Pic so you can see my dilemma.
  • Neale
    Neale
    6 years ago
    I had the same problem when I tried using it on my Electra glide.
    I get a better aspect when using a chest mounted holder.
  • mickle
    mickle
    6 years ago
    Quoting binnsy on 03 Aug 2019 07:29 AM
    https://www.rickrak.com/product/go-pro-360-mount-for-street-glide-ultra/
    Something like this may screw into/through your screen.
  • beaglebasher
    beaglebasher
    6 years ago
    Cut a hole in the screen directly in front of the go-pro.  Your welcome.
  • binnsy
    binnsy
    6 years ago
    Quoting mickle on 04 Aug 2019 02:33 AMedited: 04 Aug 2019 02:34 AM
    Looks good mickle thanks.
  • binnsy
    binnsy
    6 years ago
    Quoting Neale on 04 Aug 2019 02:26 AM
    Looked at that, thanks mate.
  • beaglebasher
    beaglebasher
    6 years ago
    Lighten up mate.
  • steelo
    steelo
    6 years ago
    Hi binnsy. I’ve got a ram mount I just put on the ultra. Attaches to underside hang grip on the mirror bolt. I was going to use it for second gps or phone x mount. Would let you swing the pv in toward risers or go pro out past the screen. Don’t forget you have the balanced motor so vibration not going to be as bad. I’ll take pics Tomoz with the ram and go pro mount attached.
    Other than that, cut a hole in the screen in front of the GoPro.
  • mickle
    mickle
    6 years ago
    Go Pro pictures taken mounted on the front right windshield screw of Ultra Limited.
    You can just see the ball mount that replaces the shield screw.
  • steelo
    steelo
    6 years ago
    I have unfulfilled love with Binnsys FB.
    6 years ago
    Quoting steelo on 05 Aug 2019 08:18 AMedited: 05 Aug 2019 10:15 AM
    FB?   Fat bum?.......Fabulous Bollocks?.......Flabby Breasts.....gee the mind boggles what happens down there in the cold
  • binnsy
    binnsy
    6 years ago
    Quoting steelo on 04 Aug 2019 12:52 PMedited: 04 Aug 2019 12:54 PM
    Wheres me pics !!!????
  • steelo
    steelo
    6 years ago
    Sorry binnsy. Looked at it today but the arms would need to be long to reach out past my screen. May be suitable for your application thinking about it. Will post soon. Sorry for delay.
  • binnsy
    binnsy
    6 years ago
    As a side note. Modest Mounts, Victoria.  Best prices on RAM mounts by far so i see.
  • binnsy
    binnsy
    6 years ago
    This is what I ended up doing,  using RAM mounts. Mirror mount,  cheap, easy and will do the job. Can rotate it in any direction and can even tuck it in behind the screen away from the bugs.
    Happy with how it turned out. On and off on seconds.
  • steelo
    steelo
    6 years ago
    You’re welcome. Good solution young binnsy.
  • JFE
    JFE
    6 years ago
    Hey Binnsy - do you notice the vibes coming through the footage when rolling or at idle?
  • binnsy
    binnsy
    6 years ago
    Quoting JFE on 18 Aug 2019 06:29 AM
    Haven't tried it out yet. The old one I had in the pic here was pretty good. Just wanted something more solid, and something I could shoot around the screen with. Will give it a try soon if the arctic weather ever stops down here.
    6 years ago
    Quoting binnsy on 18 Aug 2019 06:45 AMedited: 18 Aug 2019 06:45 AM
    Cold here as well.......26 today
  • JFE
    JFE
    6 years ago
    Too many Victorians in Qld PB!
    Cheers Binnsy.
1/3
