Online: WideglidingNZ
Dodgey fuel gauge
  • beaglebasher
    beaglebasher
    6 years ago
    Was out for a run last Sunday and the bike started coughing and farting.
    Checked the fuel gauge and it was reading full so I thought "fuck!  whats going on here?"
    Luckily I wasn't too far from a servo and rolled down the hill and put in 18 litres so the fuel gauge is fucked.
    How do you fix a fucked fuel gauge?  Its stuck on FULL
  • Wideglider
    Wideglider
    6 years ago
    Quoting beaglebasher on 01 Aug 2019 09:43 AM
    Hey BB, what model bike are you running?
    It may be that the sender (float) or wiring is the issue - not the actual gauge. Owners workshop manual will tell you what the set-up is for your bike including electrical resistance required in the circuit to gauge to provide an empty & full indication.
    Surely you must have been wondering why your bike recently achieved magnificent fuel economy!?
    I zero one of my trip meters each time I refuel, got a good feel now for how many km's before I may need to top up - I trust the odometer more than fuel gauge.
  • beaglebasher
    beaglebasher
    6 years ago
    its a 2002 fatboy.  I forget if the gauge used to  drop to empty when the ignition is off. Mine is stuck on full
  • STEAMER
    STEAMER
    6 years ago
    Quoting beaglebasher on 01 Aug 2019 10:28 AM
    Well 18.93 lt tank, so ya come close. I set my trip metre every fuel up. Then use that and guage
  • beaglebasher
    beaglebasher
    6 years ago
    Never thought to use the trip meter. I might start doing that until I get around to fixing it.
    I was hoping somebody could point me in the right direction regarding gauge /float / sender / electics etc.
  • Wideglider
    Wideglider
    6 years ago
    If you are saying that your gauge reads full with ignition off, then I would say it is the actual gauge that is at fault. Just to confirm that, disconnect all wires at gauge to see that it still reads full.
  • beaglebasher
    beaglebasher
    6 years ago
    That's what I was thinking Wideglider.  How do you remove the fuel gauge to check the wires?
    The gauge is the one on the left side of the fuel tank that looks like another fuel cap.
  • STEAMER
    STEAMER
    6 years ago
    Quoting Wideglider on 02 Aug 2019 07:53 AMedited: 02 Aug 2019 07:54 AM
    Should be able take the dash off tank, then just unplug the block, see what happens, on my 2011 fxst, there is a small plug which is for fuel gauge, and bigger block for rest of dash
  • Wideglider
    Wideglider
    6 years ago
    I'm only going by the setup on my bike ('96WG), you should be able to disconnect at conector directly under the gauge under tank. Do you have an owners workshop/service manual?
  • beaglebasher
    beaglebasher
    6 years ago
    Yeah mate I do have the manual.  I might even have a look at it !
    Thanks boys.
  • steelo
    steelo
    6 years ago
    Sorry to hear of your woes bb. Have you by any chance used e10 fuels?
  • Wideglider
    Wideglider
    6 years ago
    Here is the connector on mine.
  • Baloffski
    Baloffski
    6 years ago
    Aye wide just trying to interpret pic.
     ahh upside down view?
  • beaglebasher
    beaglebasher
    6 years ago
    Just had a look at the fuel gauge. The wire was lying on the front cylinder rocker cover.
    I cable tied it to the fuel line and it seems to be working fine now. I love that sort of shit.
    I will be using the trip meter but. Thanks for the tip.
  • Wideglider
    Wideglider
    6 years ago
    Yes wire shorting on engine/earth would do it, glad you found issue BB.
    I don't see how gauge would have read full with ignition off though, were you sure of this?
  • beaglebasher
    beaglebasher
    6 years ago
    Not 100% mate. It was reading full when it ran out of fuel but. Will be going for a run tomorrow and will keep an eye on it and the trip meter.
    6 years ago
    no fuel gauge here, I wait till I need reserve turned on. unless a long way between servo's.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Krash Kinkade on 03 Aug 2019 10:40 PM
    Forgot to turn mine back when I filled up once.....only once!
