Online: B0nes
Some cheap bits and bobs
  • Sparra
    Sparra
    6 years ago
    Has anyone on here used there 90 degree valve extenders??
  • steelo
    steelo
    6 years ago
    I bought some sparra but someone told me not to “keep” them installed due to rotational forces they put on the valve. Made sense at the time. I just carry them with me and use as required.
  • Sparra
    Sparra
    6 years ago
    Thanks  Steelo...That makes sense and just pop them on to check pressures...Will do...
    Cheers...
  • steelo
    steelo
    6 years ago
    Now having said that. The right angled ones are a PITA. If you can extend your budget, buy the flexible hose type ones
    6 years ago
    Quoting Sparra on 29 Jun 2019 10:51 PM
    Yes, makes life easy on my street glide to get that rear valve
  • Sparra
    Sparra
    6 years ago
    Quoting paulybronco on 30 Jun 2019 09:13 AM
    Do you have it on all the time or only when needed?
    6 years ago
    Quoting Sparra on 30 Jun 2019 10:29 PM
    All the time, spin it around so its going in line with the direction of the rim , done 50 k with it never a problem. I replace the valve every tyre change and get them to balance the wheel with it attached
