Online: WideglidingNZ
M8 114-CR480
  • Grease Monkey
    Grease Monkey
    6 years ago
    These things are bullshit great with a cam and tune. Durwood tuned this one, how much coin have you spent on a twin cam to get close to that!
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    That's why I bought one, about to pull the trigger on a 124 kit, estimated to get around 130HP 140T, not bad for under $5k
  • Grease Monkey
    Grease Monkey
    6 years ago
    Go 128 man, bolt on cylinders. Headwork will get you more.
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    As far as I know I cant got a 107 so 124 is the most.
  • Bigfella
    Bigfella
    6 years ago
    What bike have you got Adrian and what pipe are you going to use with the CR 480?
    6 years ago
    Quoting Grease Monkey on 27 Jun 2019 06:30 AM
    Thats a tq monster, love it
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    Quoting Bigfella on 27 Jun 2019 07:52 AM
    107 Breakout and going to use S&S 475 cam, 55mm SE inlet manifold, 5.5 injectors. Already have Freedom big radius so will stick with these for now, run out of money...lol
    6 years ago
    Good power & TQ Hilly!!
    trouble with landscape dyno graph is, it stretches out the graph so can't see any dips as easy. I like to see same run in both portrait & landscape. also like to see it in RPM & also timed so I can see how quick it made the HP & TQ as I only like to count the horses that show up in 5 seconds or less. the horses that take longer I won't even feed them as useless nags!! ( just my way of explaining, not trying to knock anything )
    the 124" I saw at Sydney drags was runing strong , had a good rider too.
    a mate that rides a 107 put a red shift cam in and a good tune, got good HP & TQ, but was saying riding two up with missus on the back. he did not like the feel of it at lower speeds, had to keep shifting down a gear on freeway. then put an Andrews cam in, it made less HP but he likes it better as. soother two up pulls harder in the rev range he rides in.
  • Grease Monkey
    Grease Monkey
    6 years ago
    No problem here Krash, not my sheets, the US lads seem to like that format, more impressive to look at for the bragging clique I guess.
    I agree it's better to have the time line on there as well, if it was my deal I would put everything up so people could see what's really going on but that's just me, what you see sells tuning gigs I guess, still just on numbers that's a good increase for the dollar spent.
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    Well had the Dyno done today on the APE 124 stump puller package and I only wished it was dry when I picked it up. Couldn't go past half throttle without the back wheel letting go 1st gear through to 4, twist it and it spins.
    6 years ago
    Quoting Adrian1200CA on 26 Jul 2019 05:57 AM
    Cant read it for shit, sorry mate what are the numbers?
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting paulybronco on 26 Jul 2019 09:14 AM
    Put ya glasses on you old goat :)
  • Grease Monkey
    Grease Monkey
    6 years ago
    Adrian did you use the 64mm TB and 550 cams?
    6 years ago
    Quoting Grease Monkey on 26 Jul 2019 09:41 AM
    Ha Ha its like looking for the Cowboys score...
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting paulybronco on 26 Jul 2019 10:49 AM
    Nasty old wrinkle, Morgan will be back next week, we can still make the finals
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    Quoting Grease Monkey on 26 Jul 2019 10:27 AM
    S&S 475 cam 55mm manifold 5.5injectors stock throttle body
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    132hp 135T
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Adrian1200CA on 26 Jul 2019 02:08 PM
    132hp 135T
    I must need glasses, I see 116hp and 134T......no?
  • Adrian1200CA
    Adrian1200CA
    6 years ago
    132hp 135T
    Quoting Grease Monkey on 26 Jul 2019 02:21 PM
    yep your right it’s me that needs the glasses 116hp 134T
    6 years ago
    That's very impressive Adrian. Lots of torque from everywhere. Can I ask what total spend was and what that included? No dramas if you'd prefer not to share.
    Also was any work done to prevent some of the issues facing M8 engines like oil migration?
