Online: Soapbox2627
Touring tripple tree
  • JR888
    JR888
    6 years ago
    I know it's a bit of a long shot, but looking for a raked tree to fit an '18 Road King.
    Just done trike conversion but need to rake the front end to make steering a bit easier.
  • HOG63
    HOG63
    6 years ago
    Raked triple trees messes up your trail. (May not matter on a trike though.)
    Either rake the frame or use raked bearing cups.
    I just installed the Vulcan Engineering 3 degree cups.
    Not sure if they make for your ride.
  • Ratbob
    Ratbob
    6 years ago
    Quoting HOG63 on 22 Jun 2019 10:47 AMedited: 22 Jun 2019 10:48 AM
    Hi Hog, What bike did you fit them to and how did they affect the distant between the yokes, the steering stop and the steering lock?
  • HOG63
    HOG63
    6 years ago
    The cups (with own bearings) fit into the yoke in place of the original bearings.
    Effectively making the yoke slightly longer and 3 degrees more rake. The bottom cup has a fork stop.
    The kit comes with a new stem to put in your lower triple that has a notch for your  steering lock.
    The system is extremely well made.
    Anyway, I’m doing some other mods to the Sporty, so haven’t got back on the road yet.
    6 years ago
    My mate installed similar on his Shadow chopper and they look really sweet.
  • JR888
    JR888
    6 years ago
    That would certainly be the easiest option, where do you get them from?
  • HOG63
    HOG63
    6 years ago
    I bought directly from:
    https://secure.vulcanworks.net/store/Fork-Cup-Set-3-Degree-Rake-2004-Up-Harley-XL-Sportsters.html
    There’s a few resellers out there though with higher prices. As before, I’m not sure for your bike. V-Twin Manufacturing also make the raked cups, but wasn’t confident re quality.
