Online: clackavosticus
Do catalytic converters really run your engine that much hotter reducing engine life?
  • matho1961
    matho1961
    6 years ago
    Do catalytic converters really run your engine that much hotter reducing engine life? Picked up my new 19 BO last week with stage 2 but stock headers and some are saying I must get rid of the headers before I stuff up the longevity of the engine. M8 cats I believe are now modified to run cooler, plus a dyno can tune the engine to almost ignore the cats. I'm a novice to all this, can anyone confirm any of this?
    6 years ago
    They run a lot hotter with a cat than without. Most late model HD have a function that allows the rear cyl to cut out at a certain temp when idling at lights etc. Cut the cat out and retune
  • Ratbob
    Ratbob
    6 years ago
    Yeah they run cooler
    And if done properly give better performance.  If anyone wants a Dyna header with the cat removed and a sleeve inserted to make it a proper dual system, l have one for sale. Ceramic coated inside and out. Cheers.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Some modern cats flow really well and that was one of the big reasons they were ditched, not sure Harley is up to speed there although I've seen dyno sheets of late with good numbers with stock headers.
    I don't know if a cat will shorten your engine life if the engine is tuned right and the factory lean condition has been eliminated but you will still have a 900°C heater near ya foot or leg.
    I was recently mucking about with mufflers and swapping them about on some weird quest and could really tell the difference heat wise when the catted mufflers were on.
    Not a fan.
  • brash
    brash
    6 years ago
    The issue is on Cold start the cats do nothing until they are up to heat.
    If you look at the cold start part of the map on the new bikes it's leaner than what I would call acceptable, this is to get the cat up to temp and in it's operating zone.
    The actual HP difference isn't as big as you think, I'll find a chart when I get in.
    6 years ago
    Not quiet on topic but still a good gauge regarding heat
    6 years ago
    Good table.   My thoughts are:  Is the reduction in temps actually of any significance?  ie are the original baseline temps within the operating range of the bike and oils in the bike?
  • Nutty
    Nutty
    6 years ago
    My oil temps on the M8 never changed after going to an open header. The HEADER certainly runs hotter with the cat in place, not noticeable on Tourers though, your foot is nowhere near the cat. The cat kills a load of dB though, factor that in if going catless on a M8, it easily doubles the noise...
  • matho1961
    matho1961
    6 years ago
    Quoting Nutty on 06 Jun 2019 10:22 AM
    Agreed. Just some bloke on a FB site said I should of changed my headers before I put the cam in, as the engine runs way hotter both with the cam and the cat still installed and that it reduces the life of the engine. With my new cam and my slip ons installed the bike is super loud. I would love the V&H big radius but as you say it would double the noise without the cat. It would be obnoxiously loud and it’s something I’m not prepared to have.
    6 years ago
    I run a decated std headers with V&H mufflers, was too loud so switched to their quiet baffles. Big difference
  • awaba
    awaba
    6 years ago
    Apologies if I'm wrong....The cats on a 19 breakout...aren't they in the mufflers...if so I would keep the headers and just fit slipons
  • matho1961
    matho1961
    6 years ago
    Quoting awaba on 07 Jun 2019 12:46 AMedited: 07 Jun 2019 12:47 AM
    Shit hey. I didnt know that. I've got aftermarket slip ons with my stock headers and all this time I thought the cam is the reason why its so loud.
  • awaba
    awaba
    6 years ago
    I bought a '17 street glide and the cat was in the header,because of the cat located in the header, the primary side exhaust was 1 & 3/4"....the high side pipe was 2 1/4"- 2 1/2" ? "..so not wanting to shell out for a new set of headers i bought slipons to fit...in 2018 the cats on the tourers were fitted into the mufflers....that pissed me no end...
    To the best of my knowledge for 2018 and 2019 the cats were fitted in the mufflers on all the big twins...excepting I believe the 2018/19 fatbob and the '19 FXDR where the cat remained in the headers for those 2 models
  • Oz Dan
    Oz Dan
    6 years ago
    The cats in your 19 Breakout ARE in your stock mufflers, not the header. So, if you run AM slip ons, you are catless.
