Online: beaglebasher, B0nes, Hilly, softfat
Heavy Synthetic Gear Oil
  • Hog1
    Hog1
    6 years ago
    Anyone using the heavy gear oil in there bike.would Like some feedback if possible please good or bad .......
    Have a SGS 18 and thinking of trying the heavy oil.
    6 years ago
    I use Redline shockproof in the gearbox and have tried every lubricant in the primary. I personally would not use ATF in the primary if you intend getting on to the throttle hard. The compensators can't cope!
  • Wholehog
    Wholehog
    6 years ago
    Quoting paulybronco on 02 Jun 2019 09:06 AM
    Redline shockproof here to !!
    6 years ago
    Quoting Wholehog on 02 Jun 2019 09:29 PM
    Liquid strawberry....
    6 years ago
    Redline shockproof in the Evo tranny and Redline normal Gear Oil in the Sporty
    6 years ago
    Another plug for Redline Heavy Shockproof gear box oil. just I can't seem to buy redline these day's & can't use it in my Sporty as they share gear box and primary & the Heavy shockproof is for gear box only. for the Sporty if I could get it I would use Redline MT, but can't find it so I just use formula from Harley , it's ok.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Not used redline, it's hit and miss getting it around here, just use a gearbox oil in the gearbox, the new HD one at 140 would be fine in the gearbox, would think it would be a bit draggy in the clutch though, I use a 10w50 in there, used to use the formula + but just get my oils from one place now.
    6 years ago
    Quoting Krash Kinkade on 02 Jun 2019 11:41 PM
    I get mine on eBay nowadays.  Good price and postage is not that bad in the end as its all AU based.  I'll have a look tonight at what 'version' of the product I use (its either the Lightweight or MT90)
  • Baloffski
    Baloffski
    6 years ago
    Big red heavy shockproof for me in the box, but trouble sourcing too. Will look on ebay, and try not tp purchase shit I don't need. Primary semi synthetic.
    6 years ago
    Quoting Baloffski on 03 Jun 2019 02:04 AM
    Bursons usually stock it and can get it in for you
  • Grease Monkey
    Grease Monkey
    6 years ago
    I used to use ATF in the primary pre 07everything and 06 Dyna, a bike guru told me no ATF and fuck no with syn 3, I've just stuck with that right or wrong.
  • beaglebasher
    beaglebasher
    6 years ago
    I used to fuck around with 3 different oils in the three holes too.
    Last oil change I filled them all up with Penrite full synthetic engine oil. 10/50 I think.
    Only done about 4000ks since but have noticed absolutely no difference whatsoever. I will be doing it again next change
    6 years ago
    What car runs a wet clutch? Bike clutch is totally different to car clutch
  • beaglebasher
    beaglebasher
    6 years ago
    Quoting paulybronco on 04 Jun 2019 10:13 AM
    Any car with an automatic transmission is basically a wet clutch
  • Baloffski
    Baloffski
    6 years ago
    loopie, love some of ya quotes.
    The old time fav is a hundred years old, "No money No Honey".
    plus, no we won't go there....
    You want long time or short time box (get ya dirty minds outta there) gear box.
  • beaglebasher
    beaglebasher
    6 years ago
    pauly is googling like fuck.
    Wait for his reply.  Might take a while
  • Baloffski
    Baloffski
    6 years ago
    Quoting beaglebasher on 04 Jun 2019 10:28 AM
    Pauly has three computers on line for quick response, aye. He is quick.
  • Big Steve
    Big Steve
    6 years ago
    Spectro for me
    There is a new version of one of these now
    6 years ago
    Quoting tussuck on 03 Jun 2019 12:57 AMedited: 03 Jun 2019 12:59 AM
    Tussuckk, thank's. used to be easy to get when the W A distributor was handling all AU redline oil's , then Graham Cowin ( rocket industries) took over & got hard to find.
    6 years ago
    Quoting beaglebasher on 04 Jun 2019 10:20 AM
    more car men in here.
