Brand New M8 Fat Clutch Pushrods
  • Oz Dan
    Oz Dan
    6 years ago
    Folks - I have (now, edited) 1 unused, brand new fatclutch pushrod from Greg Williams at Macomb County Choppers in the US.......these fix any bikes experiencing gear oil transfer from the trans to primary in the hydraulic clutch touring M8’s from 2017-present although 19 bikes will need the oil slinger removed.
    The original (Flat side) fatrod - has the machined flat edge allowing the primary to breath. This one suitable for any M8 tourer with original clutch setup without an oil slinger fitted, which was the 2017-2018 bikes. As above, will fit 2019 bikes once slinger removed.
    I have this as an extra after giving feedback help to the manufacturer on a US forum. As above, it’s brand new. I have one already in my bike and its completely halted any oil transfer. If your trans oil level keeps dropping, your oil is in the primary and this rod will fix it........never checked level? Well, go check your M8 gear oil......ok, easy fixed..... buy a fatrod......install through derby cover. Circlip plyers and screwdriver only tools required to swap out original rod....... or 10 minute shop job.
    Cost - original Flat sided fatrod - $75.00 delivered in Oz (PRICE - $80 US today from MCC)
    Save on freight and price!
  • DocGreen
    DocGreen
    6 years ago
    Quoting Oz Dan on 02 Jun 2019 02:00 AMedited: 02 Jun 2019 10:35 PM
    I'll take the cnc rod dan.
    PM sent
  • Oz Dan
    Oz Dan
    6 years ago
    Quoting DocGreen on 02 Jun 2019 09:15 AM
    PM sent
    It’s yours Doc - Pm sent man - 1 left folks
  • Cruise 62
    Cruise 62
    6 years ago
    PM sent
    Quoting Oz Dan on 02 Jun 2019 10:36 AMedited: 02 Jun 2019 09:29 PM
    Hey mate.
    Will take if still available.
    Let me know. Reply or PM
  • Oz Dan
    Oz Dan
    6 years ago
    PM sent
    Quoting Cruise 62 on 12 Jun 2019 11:14 PM
    Hey mate.
    Yes I still have the machined edge version - I’ll reserve it for you. PM sent.
  • Oz Dan
    Oz Dan
    6 years ago
    So, packaging up Cruise’s rod, I realise I actually have one more of the machined edge versions but it’s second hand.....was in my bike for 5000 odd kms - stopped transfer 100%.....
    So, if anyone else wants it I’ll put $40.00 delivered anywhere in Oz on it.....
  • Fatboy80
    Fatboy80
    6 years ago
    Hi Dan
    will the last one work on a 2017 ultra as far as I know its stock as had it from new don't believe its had the oil slinger done, im in Brisbane if that makes getting it easier if o ill take it cheers Chris PM sent
  • Oz Dan
    Oz Dan
    6 years ago
    Quoting Fatboy80 on 16 Jun 2019 06:01 AMedited: 16 Jun 2019 06:18 AM
    Hi Dan
    Yes mate it will work in your bike. I’ll reserve it for you.
    All sold now.
