Online:
clackavosticus
Tyre Puncture - is this savable?
6 years ago
Hi,
New Night Dragons and the rear was flat after work today. Limped to a garage and filled her up from a dead flat and then 'raced' home. Looks like I picked up something dead centre of the tread so it's not sidewall related. Is this something that my tyre shop can fix?
Soapbox2627
6 years ago
a couple hundred dollars, get a new one
I will plug a tire to get me to the tire shop to replace it
if you fix it and get some life from it, you will feel good, if it fails and you could feel bad or worse
WideglidingNZ
6 years ago
looks like it might be fucked, They may be able to remove tyre and patch it, but I don't think a plug will work as the slit looks to long, what a bugger
mickle
6 years ago
Quoting Soapbox2627 on 28 May 2019 02:27 PM
Good advice, if a South Australian says its fucked, its fucked.
steelo
6 years ago
Have we got a deal for you!!
These are Victorian Tourer tyres for comparison
6 years ago
Cheers.... in the shop right now getting it replaced.
Soapbox2627
6 years ago
Quoting tussuck on 29 May 2019 05:54 AM
Great choice, it just ain't worth it
Far Canal
6 years ago
Quoting steelo on 29 May 2019 03:35 AM
edited: 29 May 2019 03:45 AM
Tassie tyre wear
ralphski
6 years ago
she is FCKD.....
can't be saved
buy a new one
Baloffski
6 years ago
Definitely Cactus. Could always reuse as a neck warmer. Re: African gangers....
Now the choice.
What replacement tyre?
that goes the distance, gives -wet grip, has reasonable strong side walls, has reasonable life span, sticky, not too exxy, addressing previous - disperses water quickly and centre hard wear with centre sides not so hard.
At least these days we have tubeless, helps making the ride safer.
Decisions!
6 years ago
Sorted... rang a new to me Indie and had them fit a new Night Dragon GT. Bloody interesting ride home in a thunderstorm though...lol...nice and squirrelly in places. Got to shout out that the place is bloody top notch so if your in Melbourne’s east in Ringwood pop in and have a look at All American Motors - great guys!
Ken in Cairns
6 years ago
New tire in the rain O what fun, be nearly as bad as the stock Dunlop tractor tyre :)
Glad you got it sorted tussuck.
Baloffski
6 years ago
Ken,
you right re Dunny Original, shite, Tuss, always soft spot for the P"s and Eastern Burbs Melbourne (came therein 81) yeah previous centaury, people were old apple orchardists, etc, and were just generally cool.
Millage on P"s would be interesting Tuss, bar no unholy wire rips in side walls?
Good choice and good luck.
Just be glad I didna put up my tire wear from living on west coast WA.
Centre, was fairly weared, from north to south, till ya got to Northampton or similar name, was the only bend after sitting on 160.for 10 hours, fuck did we hook in..........
