Online: HD17
Sundowner seat
  • Daffy
    Daffy
    6 years ago
    Hi all. Anybody tried a sundowner seat on a deluxe?
    Just about to buy one. Comfy? Anybody got one to sell? Cheers
  • Ratbob
    Ratbob
    6 years ago
    Hi Daffy, do you have TC or M8 Deluxe?  I see you’re not too far out of town, have you tried that seat from Peter Stevens, they usually have or can get a loaner for you.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Not the same bike, but I have a Sundowner with backrest on my 2012 FatBob and find it pretty darn good, miles better than the stock seat.
    My kids like it too,as thay use the back rest as a handhold.
    It is a little wider than the stock seat but not an issue with fwd controls.
    As posted see if you can try one out.
  • Daffy
    Daffy
    6 years ago
    Quoting Ratbob on 20 May 2019 11:04 PMedited: 20 May 2019 11:07 PM
    Good tip. They have one I can try. Cheers
  • wello
    wello
    6 years ago
    i have the sundowner that i use on my sport glide, its as comfortable for me as the rider as the original seat but according to wife its better for her as pillion, but thats understandable as the original isnt as wide or thick as the sundowner  ... however .. the fit is pretty ordinary to be honest as id does not fit anywhere near as good up to the tank as the original and an ugly bolt is visible when i use it .. im not sure if it was designed for this bike specifically or just a softail in general as it was supplied from new by the hd dealer.
  • Daffy
    Daffy
    6 years ago
    Quoting Daffy on 20 May 2019 10:58 PM
    Well I tried the Sundowner and it is no good for me. Sits me a lot further back and being a shortass very uncomfortable. Great tip about the demo seat or I would've blown $550. Just sticking with standard for now.
