Online:
clackavosticus
Cycle Rama 480 cam
Cycle Rama 480 cam
Grease Monkey
6 years ago
I have been watching what the yanks have been doing with these M8's since they came out, especially just a stage 2 as bang for buck these new bikes respond like nothing before.
There are several really good after market cams available for the M8 but as an overall performer I reckon these new buggas top the bill, Durwood just put this sheet up, it's the second one he has tuned with this cam, impressive curves I reckon.
This was the first one I put up in Bigfellas thread.
Really looking forward to seeing what these cams do for a 114, numbers aside they are good lines.
Birtyyy
6 years ago
120Nm of torque? Sign me up!
6 years ago
Quoting Birtyyy on 16 May 2019 09:44 PM
Birtyyy , this is not a metric cruiser they are Foot Pound TQ , if converted to NM that is much higher numbers. & 100Ft lb @ 2,000.
dyna13
6 years ago
Second with just the stock head pipes and no head work, very smooth. Was thinking maybe a new 2020 114 tourer but with these numbers a late runout 2019 107 and the difference in coin?
dyna13
6 years ago
I wonder which FM slip ons maybe Jackpot 4" Dyno Tuned Mufflers? Worth a email to find out
JACKPOT 4" DYNO TUNED MUFFLERS
Jackpot Dyno tuned 4" mufflers feature our legendary Fuel Moto dyno tuned baffle system. We have spent countless hours testing different baffle designs, configurations and dyno tuning to offer the best performing slip on mufflers available. These mufflers were designed specifically to be used with the stock Harley head pipes, as well as a stage 1 air cleaner and Dynojet Power Vision or Power Commander (or appropriate EFI tuner). Jackpot mufflers offer the ultimate combination of performance and sound. The sound quality of these mufflers is truly second to none. Jackpot Dyno tuned mufflers provide a deep, rich tone that provides a true V-Twin note. They emit a very reasonable sound level in the idle and cruise range areas, and a nice powerful rumble in the upper RPM's.
6 years ago
The M8's are really showing some good numbers.
Interesting to see how they hold up .
This is an Aussie built setup:
APE 128” Stump puller package
• A.P.E 128” Bolt on kit
• S&S Cycle, Inc. 475c Cam
• Screamin Eagle 55mm Extreme Flow inlet manifold
• Screamin Eagle 5.5gps injectors
• D&D Exhaust Low Cat 2-1
• Stock Cylinder Heads, Stock Throttle body
124.91hp 145.89ft lb ????
This package retails at $4800 ride in ride out from Stage 1
Grease Monkey
6 years ago
Apparently they can have crank issues, not slipping like the twin cams but tight in the bearings somehow, even so that's a minority, those stock heads must really flow well.
Bigfella
6 years ago
Thanks to GM........Giddy Up!
Just don't know who I can get to tune it and do it justice!
Grease Monkey
6 years ago
Bloody money pits I tell ya :)
Bigfella
6 years ago
Quoting Grease Monkey on 19 May 2019 10:07 AM
Now customs want $90 to process parcel even though if falls under a free tariff.......the c_#ts! Everyfuckenone wants a drink :(
