Online: beaglebasher, B0nes, GGUser200, softfat
Noisy front brake solved.
  • Smokey61
    Smokey61
    6 years ago
    Lyndal Z-Plus pads. Gone from a cicada colony to library quiet. YMMV.
  • steelo
    steelo
    6 years ago
    Well done Smokey. Glad that’s sorted.
  • Ratbob
    Ratbob
    6 years ago
    Quoting Smokey61 on 04 May 2019 07:25 AM
    How many Ks have they been fitted Smokey?
  • Smokey61
    Smokey61
    6 years ago
    Quoting Ratbob on 04 May 2019 08:54 AM
    About 30kms.
    6 years ago
    They are good pads too.  Pretty much dust free
  • Wideglider
    Wideglider
    6 years ago
    Glad you got it sorted Smokey - thanks for the feedback.
  • Ratbob
    Ratbob
    6 years ago
    Quoting Smokey61 on 04 May 2019 11:17 AM
    About 30kms.
    Thanks, I’m wondering if there’s a wear in period before the noise returns. I changed discs recently, using the same pads and she’s also quieter and brakes better, wonder if it’ll stay that way.
  • Smokey61
    Smokey61
    6 years ago
    About 30kms.
    Quoting Ratbob on 04 May 2019 12:02 PM
    I changed to OEM pads at first, still noisy, noise was there right from the first brake application. In contrast, the Lyndal Z-Plus pads were silent right from the start.
  • Ratbob
    Ratbob
    6 years ago
    Thanks Smokey.
  • brash
    brash
    6 years ago
    Good info, I'll have a look at them when they are due.
    6 years ago
    As i stated in the other thread my lyndell z   make noise on both my bikes
    But I run braided lines. So maybe that’s why   . ?
    But I wouldn’t use any other pads that’s for sure
    Shit loads less dust
    6 years ago
    Quoting perthhog on 16 May 2019 08:55 AM
    The same pads in mine make the noise
