Online: beaglebasher, B0nes, GGUser200, Hilly, softfat
Analyse This
  • Grease Monkey
    Grease Monkey
    6 years ago
    Tune?
    Clutch?
    Tyre slip?
    Idea's?
    6 years ago
    What was the dyno tuning ....car or bike?  My first impression was a speed restrictor/limiter
  • Grease Monkey
    Grease Monkey
    6 years ago
    Nar it's my 110 on the dyno, it's on smoothing 5, something or somethings is amiss, just curious as to what people think could be the issue looking at that printout, not numbers, unless it's to do with a why.
  • Wideglider
    Wideglider
    6 years ago
    Quoting Grease Monkey on 03 May 2019 12:46 PM
    Dyno monitoring issue?
    Surely the dyno operator has an idea what the story is for you??
  • Grease Monkey
    Grease Monkey
    6 years ago
    Appreciate the input Hoody, I tuned it, I want Lushy to do it, trying to sort something later in the year.
    The graph was just a fun day mate, I put on their dyno for shits and giggles not for bragging rights, the numbers are irrelevant to me but state of tune matters, my concern is how rough the line is, yeah it could be the sensitivity of the dyno but my mates bike (which we also tuned on the road) on smoothing 5 had a nice clean line, I did use MyTune on my mates bike but haven't on mine as yet as my tablet died and I don't have the program on the office computer...yet.
    So in brief there is no normal dyno sheet for my bike as yet.
  • brash
    brash
    6 years ago
    belt refraction
    5th gear pull Im presuming.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting brash on 04 May 2019 04:27 AM
    belt refraction
    Thanks Brash, mate it could of been 4th or 5th gear, I don't know as it was in and out real quick with no talk time with the operator, I'm not used to hearing my bike rev from outside a booth but it sounded like it was up there rpm wise, it still accelerates in 5th and 6th at 180 so I'm leaning towards 4th gear run, hard to tell with so little info.
    Belt refraction wasn't something I'd thought of, cheers for that, my concern is line being so jagged at that smoothing level.
  • brucefxdl
    brucefxdl
    6 years ago
    next to your crystal ball probably,seems some think money can buy whatever they think of.a bloke with money,and loose roos in the top paddock ,asked if we could fit an extra gear in his xr honda,a bit lower than first would have been good he said,when i replied no,he said i have money...i walked away.
    6 years ago
    I have never heard the term "refraction" used in that way. (normally applied to light or sound waves)
    I'm guessing you mean deflection ?
    I really wouldn't worry about the small spikes, and I doubt they would have anything to do with the tune.
    Checked your wheel bearings lately ?
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting speedzter on 04 May 2019 05:57 AM
    Cheers mate, 3000k's ago I did....bloody hell, now I got to look! thanks though, appreciate it.
  • Lushy
    Lushy
    6 years ago
    In the absence of any wheel brg, drivetrain issues, it sort of looks like the WOT end of the map is struggling,almost missing. It would be 4th gear. What is your engine combo? My bet would be too rich on fuel. If it was too lean I think it would be a jagged, spikey looking line.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Lushy on 06 May 2019 04:34 AM
    Hey Nev,
    Softail CVO 110 engine
    Stock heads
    SE58mm TB 5.3 injectors
    10.5 pistons
    .030" headgaskets
    T-Man 590PS2 cams
    Rush 2 into 1 headers
    2.5" baffle, trapped end, open cap, 18 discs
    You could be right about it being rich up top, will check that again asap.
    Cheers mate, appreciate your time.
  • Lushy
    Lushy
    6 years ago
    !! It is missing about 15+hp. Did the guy have a sniffer in the exhaust ? Not familiar with the cam spec.
  • Lushy
    Lushy
    6 years ago
    Looked up the cam, very short timing for 10.5 comp, my guess is too rich on fuel and knock sensor pulling out a heap of timing.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Thanks Lushy, I have to take responsibility for the tune, my first thought when I saw the line was tune is up the shit, I posted it here to see what others thought, when I put this pipe back on, even though I don't like the program, I did a couple of smart tunes, no timing adjustments.
    It won't be 10.5, pistons were down the hole a little, be 10.2ish, haven't measured it as it is what it is and T-Man say that 10.5 is ok for the cam, I'm still trying to swing a trip to Victor Harbour. September....maybe.
    Will get MyTune on my working computer and run a few logs through that until I can get it tuned properly.
  • robots
    robots
    6 years ago
    How the plugs look
    Winter's coming up
  • Baloffski
    Baloffski
    6 years ago
    Quoting robots on 07 May 2019 09:36 AMedited: 07 May 2019 09:59 AM
    How the plugs look
    Winter's coming up
    Shit robots if that's not a good, but dam leading question, I don't know.
    Quite often winter is the spend and get done time, aye.
  • Grease Monkey
    Grease Monkey
    6 years ago
    It'll get sorted one way or another, no winter up here ;)
  • robots
    robots
    6 years ago
    How the plugs look
    Winter's coming up
    Quoting Baloffski on 07 May 2019 11:56 AM
    Yes, spend spend spend
  • Grease Monkey
    Grease Monkey
    6 years ago
    Thanks for all the info and education gentlemen, appreciate the input, seems I have to rethink a few things.
