Online: Hilly, Merv
Harley Wildfire
  • Ratbob
    Ratbob
    6 years ago
    Well at least with their short range, you won’t be far from home when it lights up.
  • Wideglider
    Wideglider
    6 years ago
    New technology always has teething issues. As catastrophic as some failures may be sometimes, all issues eventually are overcome.
    6 years ago
    Quoting Ratbob on 30 Apr 2019 09:42 AM
    Ha Ha so be like the Lebo bikies and were your Nike joggers so you can walk home
  • Soapbox2627
    Soapbox2627
    6 years ago
    Quoting paulybronco on 30 Apr 2019 12:21 PM
    I done 400k's on my bike today in my Nike joggers
  • Ratbob
    Ratbob
    6 years ago
    Quoting Wideglider on 30 Apr 2019 11:57 AM
    and sometimes by taking them off the market.
  • Ratbob
    Ratbob
    6 years ago
    I don’t think you misunderstood it loopie, but using engine as a stressed member isn’t new. In “a good accident” as you called it, most bikes are written off anyway.
    6 years ago
    Quoting Soapbox2627 on 30 Apr 2019 01:09 PM
    Yes but your from SA ....that is a step up in safety from QLD thongs if your rich or barefeet if your a stoner
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I wonder of you could just get a new motor casing and reuse the rotor etc.
  • Ratbob
    Ratbob
    6 years ago
    Quoting Ken in Cairns on 02 May 2019 08:51 AM
    I think Loopie is over doing it. Take a Twin Cam Dyna, the swing arm is attached to the back of the trani so the “engine” is part of the frames dynamic. A good side or rear hit will stuff that union. No one worries about it cause the bike will be written off.
    The Live wire engine isn’t really a stressed member. The frame will cop it before the engine. From the pics the engine hangs under the battery, buying a new unit might not be more expensive than buying a new transmission but being fair to old mate Loopie, that’s still unknown.
    But hey, there’s plenty of bikes out there using the engine as a stressed part of the frame and it’s not been an issue.
  • Ratbob
    Ratbob
    6 years ago
    I agree mate, for now the Livewire is a city bike, ain’t saying it’s bad but the current declared range is a killer.
