Online: Soapbox2627, Hilly
Too much shaking?
  • Fxdb2007
    Fxdb2007
    6 years ago
    So my mates have been telling me my motor shakes too much at idle (it's a Harley, I tell them. And it's a rubber mount). They've all got softails with the B motor - so they get no idle vibes at all, hence their opinion that mine shakes too much. I like how it shakes, afterall, it's one of the reasons I bought a Dyna and not a Softail. But how much is too much shaking?
  • Wholehog
    Wholehog
    6 years ago
    Quoting Fxdb2007 on 27 Apr 2019 01:39 AMedited: 27 Apr 2019 01:57 AM
    It’s fine man.....fkn softail riders ,their soft !
  • Ratbob
    Ratbob
    6 years ago
    Yep, she's shaking more than a drunken belly dancer, perfect.
  • Wideglider
    Wideglider
    6 years ago
    It's more than likely all good, all part of the overall Dyna experience! But hard to tell exactly from the vid.
    Wouldn't hurt just to check front & rear rubber engine mounts as part of regular maintenance inspection, my Dyna had rubber cracked through & was causing excessive shaking.
  • Fxdb2007
    Fxdb2007
    6 years ago
    Cheers guys. Was 90% sure it was running ormal but they sowed a small seed of doubt in there.
    Wideglider - cheers. Replaced the front motor mount about a fortnight ago as the front header was occasionally contacting the frame under hard braking or bumps. Rear looked good, although is hard to tell without taking it out.
    6 years ago
    Fxdb2007, looks about normal , but I think with a good tune ( someone that can custom map the EFI ) it would smooth out a bit, sounds fast in the idle too, but that is the tune. when people I meet with Harleys hear my Sporty idle they sometimes mention they wish they could get there EFI to idle like that. ( carb )
  • bloodog
    bloodog
    6 years ago
    Ratbob
  • Fxdb2007
    Fxdb2007
    6 years ago
    Quoting Krash Kinkade on 27 Apr 2019 06:14 AM
    Idle is between 900-1k rpm. I don't have a tach but that's what the FuelPak tells me.
    The shaking doesn't bother me, rather I wanted to confirm that it's about as "violent" as expected,and not indicative of any underlying issues. Highway speeds and this thing purrs!
  • JFE
    JFE
    6 years ago
    Long live the Dyna shake!
  • Big Steve
    Big Steve
    6 years ago
    Looks a little vibey but not rattling the heads off.
    How many km on your current mounts?
  • Fxdb2007
    Fxdb2007
    6 years ago
    Quoting Big Steve on 27 Apr 2019 08:53 AM
    Front has about 100klms. Replaced it myself about a month ago. Smoothed out low end throttle inputs no end.
    Rear I'm not sure. I haven't touched it since I got it, but it looks solid, at least what I can see of it. Bike has 23 thou on it so likely it's original.
    6 years ago
    No Worries, was just mentioning, a good tune would be noticeable.
    also with the rubber mount motor, the stabilisers limit side to side movement, but not forward to rear movement, so putting a stabiliser that limits forward to rear movement, a good thing. I once broke the rear rubber mount on my old twin cam cam dyna, when I was racing it at drags. when I hit 160kph it started a rear end wobble, opening throttle hard did not help, it got worse. so I held throttle open & used rear brake at same time & that helped stop it till I could slow bike down. but not a nice feeling I can tell you!!
  • Fxdb2007
    Fxdb2007
    6 years ago
    Quoting Krash Kinkade on 27 Apr 2019 08:23 PM
    A real sh*t your pants moment right there!
    6 years ago
    Double check the front engine mount...they get floppy when the mount chits itself (you have to remove it to check as the engine weight can hide the issue.  Cheap fix.
  • Smokey61
    Smokey61
    6 years ago
    Normal, but you might consider a Predator front engine mount.
  • Sponge Boy
    Sponge Boy
    6 years ago
    Nothing wrong with that mate; Love it !
