Online: clackavosticus
95FXD 1340 Gasket help
1/3
  • 95FXDWG
    95FXDWG
    6 years ago
    Hey fellas, super new to HD's and just bought this 95 wide glide. The previous owner didn't take to much care of it and has siliconed the outside of where the primary connects to the case instead of replacing the gasket. Just seeing if there is a primary rebuild kit that includes the gasket? I have attached a photo for reference.
  • Far Canal
    Far Canal
    6 years ago
    6 years ago
    Quoting 95FXDWG on 25 Apr 2019 06:43 AM
    Evos are prone to base gasket leak. Seller may have applied a band aid fix for the sale. Often it's only a weep and not a big deal.
    Lots of gasket kits to replace what you have. James base gasket kit gets a good wrap also take a look at:
    6 years ago
    Agree weeps vs leaks. But where that slaz is I would say the engine case primary lip has a crack in it
    You will have to degrease and clean the slaz off  if it does have crack  there is a repair gasket
    That is made to fix this problem  James make it buy memory I’ve not used one  but apparently
    That is the fix  or remove engine strip and repair  hopefully I haven’t jinxed you
    But also there’s  normally a big o ring which goes between the inner primary and engine case lip
    That’s where the o ring sits  so hopefully it’s just a o ring  that needs replacing
  • 95FXDWG
    95FXDWG
    6 years ago
    Cheers fellas, It was pissing oil out on the way home so hopefully not a crack! Ill tear it down and have a look in a few days.
  • Sav117
    Sav117
    6 years ago
    I bought mine from Harley directly. The guy who owned my bike before my out Black Silicone on EVERYTHING was really annoying. But got the proper gaskets from Harley and I no more leaks :)
    Mine is a 96 Fatboy
    6 years ago
    Quoting perthhog on 25 Apr 2019 10:26 AM
    Agree 100%.  Thats the old lip crack issue.  And your right there is a fix kit for it - I think it involves welding though.
    I would degrease the entire lot as there could also be a base gasket leak in that mess as well.
  • 95FXDWG
    95FXDWG
    6 years ago
    The crack is pretty bad, the o ring can't even sit on the lip and the even with the gasket repair kit I can still get a feeler gauge in. Any ideas? I was just going to try the James repair gasket and some high temp sealant. Just trying to avoid buying a new engine
    6 years ago
    Sorry I jinxed  the situation ?? But I would ether trying the James gasket if you cant  get one. Or
    I would make one  out gasket paper  draw it out off the inner primary  than  all cleaned up
    With with thiners or carbi cleaner than put some pematex aviation goo on the gasket
    Than assembly it  but as you I would be trying everything before removing  to fix or
    Replace engine , not sure what the procedure is for rubber mount engines but on softails
    You leave the trans loose on on the frame aswell as engine  than do up the inner primary
    So there not fighting each other than do up there mount bolts   To avoid this situation
    Good luck
    6 years ago
    I remember seeing a kit that replaced the old lip with a new one.  It does involve machineing the cases to smooth stuff out and then I 'think' the new part is welded into place OR it may just be a compression fit like a gasket.
    It involved a metal ring but I cannot find reference to it.
    The James gasket/foam kit is supposed to resolve the problem.  I have also heard of great success with JB Steelstick which is a putty like JB weld so can be formed.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Tussuck is there an o'ring groove in the inner primary mating surface?
    6 years ago
    Quoting Grease Monkey on 06 May 2019 02:01 AM
    Yes there is a receiver grove in the inner primary hilly
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting perthhog on 06 May 2019 02:09 AM
    This might sound a bit rough but would it be possible to superglue the new o'ring into the groove and fit it up?
    6 years ago
    Quoting Grease Monkey on 06 May 2019 02:15 AM
    Think it might fail due to how much of the lip is gone  I think I would try what I said before but maybe as a
     As tussk  said  some salz aswell.  Remove the rotor than slaz the grove from the inside  it’s  at the stage really
    Patch it up or remove and fix as mr hood said Or  go open belt drive but that’s not for me
    Combination of  gasket , aviation goo, slaz might just work for a while till the motor needs to be removed
    For other work or upgrade. What’s the worst that could happen  leak oil again  I would try it  bit of time
    And what $50  Of consumables
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting perthhog on 06 May 2019 02:25 AMedited: 06 May 2019 02:30 AM
    I would go with what you blokes suggest, such a bugga because to fix it properly is a major job engine wise.
    6 years ago
    Actually,
    Reading up on the James Gasket kit that might be worth a try.
    It totally ignores the lip issue and works to provide a damn good seal between the case and inner primary through a special gasket material.  get the kit, make sure both mating surfaces are clean and flat and then have a crack at it.  If it still leaks then plan 'B' could be the repair using metal putty option.
  • OILLEAK2008
    OILLEAK2008
    6 years ago
    The question begs - why did you buy it in the first place?
  • 95FXDWG
    95FXDWG
    6 years ago
    Thanks guys, ended up getting everything out using the gasket kit with sealant together it came out look absolutely beautiful without a drop of oil coming out! Now just to replace the rectifier and she is all done!
    Also I didn't buy it I bought a 650cc about 2 years ago for 3000 and have been swapping and trading it up making money until i finally gave a bloke 2000 and a suzuki gs1250s for it so I didn't care if I needed to fix it up a bit. I'll end up putting a S&S in it later anyway. So in my eyes it was an absolute deal.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting 95FXDWG on 13 May 2019 08:14 AM
    You done good and it looks great.
  • Wideglider
    Wideglider
    6 years ago
    A good result from your fix, bike looks good (from a '96WG owner).
1/3
