Online: beaglebasher, B0nes, Hilly, softfat
Breakout exhaust on Fatboy
  • Drac
    Drac
    6 years ago
    Hi
    Does anybody know if a breakout exhaust will bolt onto my 2012 Fatboy?
  • Retroman
    6 years ago
    Probably not. Breakout has 240 rear , especially the rear downpipe "kicks out" more.
    Breakout mufflers are like Heritage/Softail custom mounting bolts/brackets , again different from Fatboy
  • Drac
    Drac
    6 years ago
    I thought the wider wheel may be a factor
    Thanks
  • Grease Monkey
    Grease Monkey
    6 years ago
    Had one on my Softail Slim Drac, as Retro said it does hang out a little but it's bugga all and actually looks good, if the system is complete it will bolt on no issue. Scrounge up a pic for you if I can.
  • Grease Monkey
    Grease Monkey
    6 years ago
    That's with black heat shields but it's a breakout system.
  • Retroman
    6 years ago
    Aha so it does "fit". My experience is all of trying to retrofit the "other way" , 200/narrow rear system onto a 240 rear and that no way works..not without engineering input !
    I had to compliance a couple of 2009 CVO Springers a few years back and no stock Softail 180/200 rear systems fitted ( first/second model/year of the 240 rear you see !)
    In those cases I used a Rocker stock system ( 240 rear !) , downpipes and mufflers. Still got that in the shed "for later" haha..
    EDIT watch out for the different O2 sensors across the model years , both size and location . That alone may make it "too hard basket"
    It would for me anyways. 2011 the O2 sensors changed so Breakout and 2012 Fatboy should be OK and good to go
  • Drac
    Drac
    6 years ago
    Thanks for the info guys
    Easyr has a set of Rinehart kickbacks for a Breakout for under $500
    Not sure if I will do it yet
