Online:
beaglebasher, B0nes, Hilly, softfat
Evo 1340 oil breather kit
Sporty
6 years ago
Just did a complete rebuild on my 1340evo, few upgrades, cam, etc.., getting a fair bit of oil (spray?) from oil tank dip stick, which I’ve now ordered a new one to better seal!, but the heads section where the rubber boots are, are oily, especially when running at over 100kph, can anyone recommend a breather carby bypass kit?
So I can get rid of smokey oil going back in the motor? And making an oily mess of the right hand side of motor.
I have replaced the rubber boots, but doesn’t seal tight enough, and the problem reoccurring
Bigfella
6 years ago
Not sure about local EBS kits or options, but these guys have a few available
http://www.dkcustomproducts.com
Hope that helps
Sporty
6 years ago
Quoting Bigfella on 22 Apr 2019 01:56 PM
Hope that helps
I’ll check it out, thanks
6 years ago
Head breather or crankcase .?
, check valve ball bearing in oil pump may have
Crap on it or stuck / sticking causing excessive oil blow by. Tank not over filed is it
Sporty
6 years ago
All good!, took rocker covers off, found little rubber blow off valve in the wrong spot on the front cylinder, refitted in the right place, no more issues ??
Cheers and thanks for the assistance
